M11 setup tips
Old 02-07-2009 | 03:45 PM
Default M11 setup tips
So I just bought a m11 dsss today, and was wondering what types of functions and setups you guys use. This is going into a Hot Bodies D8 so if any of you guys could post some of the setup functions you use that would be great. I am reading the manual as of right now and this thing just has sooo many options. Trying to see what is good to use or not.
xpertpredator is offline
Old 02-07-2009 | 04:12 PM
Funny, I just got mine today as well. bought it used from this site. Holy crap its like a laptop with a trigger and steering wheel.
Anyway, I was wondering the same thing, I run nitro offroad and was interested in the dual rate and mixing options. I am kinda a twitchy driver and I wonder if this would help slow down my inputs when at full throttle to keep the buggy stable.?
Ill keep watching this thread
Chris
schultztec is offline
Old 02-07-2009 | 04:26 PM
Kind of a stupid question but do i set it too 4 or 2 channel?
Old 02-07-2009 | 04:49 PM
2 channel .. 1 for throttle and 1 for steering
chris
Old 02-07-2009 | 04:57 PM
will my transponder work on 2 channel.
Old 02-07-2009 | 05:07 PM
I have no idea on that one, Havent got a transponder yet so im not sure how they are installed
** Can anyone else help us out. I feel like the blind leading the blind!!!**
chris
Old 02-07-2009 | 05:09 PM
lol tell me about it. The radio is awesome though, just so many features that I dont know where to begin.
Old 02-08-2009 | 05:58 AM
staikosn1's Avatar
I need an advice guyz from someone that knows... i want to change the wire antenna from receiver.... i have to put the same antenna from sanwa or i can put from futaba for example??? where i can find that antenna wire??
staikosn1 is offline
Old 02-08-2009 | 06:51 AM
lil-bump's Avatar
there is no magical setup tips for a radio. Just make the servos turn the right way. The only thing I would setup is you end points. make you don't drive your servo too far.
In these type of radio 2 channels may give a little quicker response than 4 channel. Unless you are running a vehicle that has more than 2 servos (steering and throttle) then keep it in 2 channels
Your transponder has nothing to do with how channels your radio uses. The transponder plugs into an aux port on your receiver.
Pass you all soon...
lil-bump is offline
Old 02-08-2009 | 01:15 PM
staikosn1's Avatar
some help here??
Old 02-08-2009 | 01:21 PM
wingracer's Avatar
A similar type of wire of the EXACT SAME LENGTH should do just fine.
wingracer is offline
Old 02-08-2009 | 06:33 PM
UltegraSTI's Avatar
best advice i can give is that u'll never use all the function, u'll never understand all the functions, so leave them alone and work with what u would normally and KISS. thats what i do. heck it still in the bad, havent used it yet in almost 2yrs now since i bought it. still on the trusty m8
R
UltegraSTI is offline
Old 02-08-2009 | 09:11 PM
tdr170's Avatar
Default Transponder
The transponder plugs into the receiver so you need a minimum of three channels.
Your steering and throttle use 1 and 2 then the transponder would plug into 3.
Mugen MRX4X - Picco P9 Evo
tdr170 is offline
Old 02-09-2009 | 12:39 AM
staikosn1's Avatar
I think that in 2,4Gh is more complicated!!
Old 02-09-2009 | 11:05 AM
staikosn1's Avatar
I ve heard that the 2,4 is not as simple as common receiver!!!!!!!!is that true?
