Info on Turnigy Accucel 6
#171
Help me take a walk down memory lane...with your help
oops wrong thread
#173
This is what HC sells to do that - the harness plugs into the side of the charger and then tise adapter board. I bought the other 3 types of balance conns with my Accucel-6 so I;d have them all.
http://www.hobbycity.com/hobbycity/s...idProduct=7350
This is shown near the bottom of the page where the charger is shown by itself on HC.
#174
#175
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
#176
Got tired of not being able to balance them, so just bought them all. I've used all of them except the Kokam one.
Yeah, I'm prob just going to order the specific adapter on eBay so I don't have to wait 10-14 days.....otherwise I'd hobbyking
#177
I see this being discussed so I assume I can't do it. I have a hyperion lipo battery and I want to balance the battery on the Accucel 6. There is a 5 prong input on the Accucel 6, but I am assuming that is not for balancing hyperion batteries which is why you are buying adapters?
I noticed the hyperion battery wouldn't fit due to the clip on the balance plug anyway. Only way to make it work would be to cut the clip.
#178
#179
The Accucel-6 takes JST-XH (also called Align) type balance connection. Hyperion uses something different, it wouldn't work and you risk shorting something in the charger putting voltage where its not expected.
Just get the proper Hyperion type balance adapter. Look on the page where HC lists the Accucel-6 down toward the bottom, they list the adapters. Plus as y2kgtp has found, you can get adapters on eBay as well.
#180
Another advantage is that you get more reach into a LiPo charging sack when your at the track.....some balance tabs you get like 2" off the pack and have to almost put the charger in the sack as well.....
