electronic problems
Old 09-19-2008 | 03:49 AM
Default electronic problems
ever since i went to novak hv maxx brushless system my rc car. i still have the stock traxxas receiver and controller setup. when i run the car around it seems to take off on its own at low speeds. i can still control it with the breaks. but i was wondering what i can do to fix this from happening.
bluefire1984 is offline
Old 09-19-2008 | 05:36 AM
offtraxx's Avatar
read short signal in this area. try turning your throttle nob on the radio,does the motor make noise when sittong still?
offtraxx is offline
Old 09-19-2008 | 08:25 AM
Try turning down the throttle trim on your tx.
Duster_360 is offline
Old 09-25-2008 | 11:00 PM
Default tried
alright i tried moving wires i tried redoing all my trims...... still glitchs at short range with the stock setup work just fine. can anyone help me
Old 09-26-2008 | 04:00 AM
There are lots of the Novak HV's running in TRX rcs. You have some kind of problem. Ck the antenna wire - look for a nick or slice of some kind. Make sure antenna wire does not touch chassis. I 've seen some advice to braid the motor wires to reduce any field.
Obvious - tx/rx batts are fully charged?
Email Novak - ck their site, one of their guys is bound to post here - I know they do on RCCA and RCM.
Old 09-27-2008 | 05:54 AM
Default thanks
i'll try doing that if it don't work i'll go complain to novak see whats going on. wish things just worked right from right out of the box bc its a blast to drive.
