Ezrun ESC
Hi Guys!
I just bought a Ezrun ESC and I am trying to set up according to the instructions, I am at the stage to calibrate the throttle and been finding difficulty...
The instructions states to Hold the "Set" button and then turn on the ESC until the the Red LED flashes, which i can achieve at times. Then it says to pull the controller throttle fully back and then push the set button once more in which u should get a Green LED flashing once with a "Beep" from the Motor...however i have tried this and it doesn't seem to work! I been searchin around for answers to no avail..
Can anyone give me a solution or have come across this problem?
Thanks in advance for your help!!
Thanks for your dethklok151!
I just found out i mis-connected the wires to my reciever....problem solved and i managed to get the throttle range calibrated!
Now the next problem is i got my program card with it - i connected it up to the ESC and battery and it doesn't seem to work at all ie. no numbers light up or anything!! Any Suggestions??
I have one.. make sure you have the esc plugged into the correct input on the card and the correct way. It is marked.
Make sure the battery is charged too.. then turn it on.
If it's not working, something may be wrong with either the card or the esc... i believe you can program it without the card, but it looks a bit complicated.
Jerome
Jerome
Hi Guys!
Regards.
Thanks for your relpies everyone, really appreciate the help in here!!
I managed to get it working - think it was cos i connected the ends incorrectly into the programme box! Now i can finally start building my Active A210SS, can't wait to get it up and running!
hi,
I just recently brought a acme raptor brushless rc truggy with a brushless motor and esc i have tried every thing on youtube and I still cant get anything to work would it be better if I get a programme card as this is my 1st brushless rc car
please help!!!!!!!!
please help!!!!!!!!
