AMB RC decoder
Old 07-25-2011 | 07:36 PM
  #31
smilekt's Avatar
Originally Posted by promatchracer
How wide is your loop
Also do you have a Mike or other Electrical cables running near the loop cable
At one of our big races we moved the announcers section and ran the mic cable up right next to the coax for the loop. We didn't realize it at the time but it was causing missed laps We found out about 6 months later when we talked to someone else and they had mentioned it
Hope some of this helps
hi promathchracer
Thank for the advice. the loop wide is standard around 12 inch to 14 inch.
and of course we have PA system near around 1.5 meter distant from decoder. PA system from loop cable is around 3 meter.
but every car passing beeb sound look like delay in half second .. car passing after half second the beep sound on.
Thanks ..
smilekt is offline
Old 07-26-2011 | 01:50 PM
  #32
Ed Anderson's Avatar
Could be a software issue.
I upgraded my rc decoder to a rc3,... everything worked fine. The following season I set everything up the week before my first race. I had a similar problem.. there was about a 4 - 5 second delay after the car crossed the line... I hadn't changed anything... or so I thought. Something had changed in the OS (windows). Called the writer of my software (Autoscore), and he told me I needed an update... emailed me the update and everything worked fine.
Might want to check it out.
Ed Anderson is offline
Old 08-21-2011 | 07:16 PM
  #33
smilekt's Avatar
thank so much Ed Anderson .. sorry for late reply .. now we are upgrade to rc3 .. not test yet ... next will have race meeting
smilekt is offline
Old 05-26-2013 | 09:34 PM
  #34
morocho1979's Avatar
Hello any one have the use drivers for Windows 7 or Windows 8 64bits i try my old usb drivers but don'twork de my decoder is a rc2 another question the rc3 with ethernet work with windows 8?? Thx
morocho1979 is offline
Old 05-27-2013 | 10:43 AM
  #35
Bob Malphurs's Avatar
No AMB (MyLaps) USB drivers for 64bit Windows OS.
Assuming you have the AMB RC2 decoder you may get it to work with serial cable (rs232) from decoder to serial on computer. Or a serial to USB adapter, that's serial port from decoder to USB port on computer.
Bob Malphurs is offline
