help with binding/unbinding >
Old 08-11-2008 | 05:57 PM
jatodriver93's Avatar
Default help with binding/unbinding
i have a futaba 3pks with the spektrum sm1000module
and im trying to bind this remote to the recievers binded to an old spektrum dx3
several questions:
can you unbind or do you just bind to another remote?
when i try to bind the reciever to my 3pks the lights will flash and then my b44 will just start accellerating like crazy
jatodriver93 is offline
Old 08-11-2008 | 06:16 PM
FOXY923's Avatar
You don't need to unbind. Just follow the binding instructions and it should work.
Turn off car & Tx. Press and hold bind button on Rx, turn on car's power. Light will blink...nothing else should be happening with the car. Press & hold bind button on Tx. Turn on Tx...light will flash. Once light is solid the Tx & Rx are bound.
FOXY923 is offline
Old 08-11-2008 | 06:29 PM
thanks but when they say the tx and rx say that they are "bound" the b44 just accelerates to max like im holding the gas down
Old 08-11-2008 | 06:51 PM
FOXY923's Avatar
You may need to adjust your throttle trim settings. Best to start with them at neutral. Also, when you turn on your Tx in the bind process make sure you have your finger on the brake, this will set your failsafe.
FOXY923 is offline
Old 08-11-2008 | 08:15 PM
After changing radios you can reset the speed control to that radio, that should take care of the throttle issue. And adjust your steering endpoints. Every radio is a little different, especially if you jump brands.
Dave H is offline
Old 08-11-2008 | 08:25 PM
FOXY923's Avatar
I didn't even think of resetting the esc Do this and the others and you should be good to go.
FOXY923 is offline
Old 08-11-2008 | 08:56 PM
im not sure i its all model specific but if i had the lrp sphere how would i reset it? would it be button pressing, if so ill check my manual
Old 08-12-2008 | 06:43 PM
allright i finally got around to trying to reset the esc but if anyone with the sphere could help clearify how to reset it because im not sure if im suposed to plug the esc into the receiever and if so where, and then once i do that i know im supposed to hold the set button for three seconds
but i tried by not plugging the esc into the reciever and held down the button, but it never flashes
Old 08-12-2008 | 07:56 PM
Bulldawg RC's Avatar
you need communication with the radio Skip or else you can not program the speed control.
Bulldawg RC is offline
Old 08-12-2008 | 07:59 PM
hey man, i guess you can see i got the controller.
ok so the speed control has to be plugged in to the reciver, but if i put it on the throttle and turn it on the car goes off like crazy without pulling the trigger
should i just take off the tires and program it while its going full throttle?
Old 08-12-2008 | 08:01 PM
you have to hold the esc set button before turning on the car, this will not allow the car to move and will automatically enter into program mode
Old 08-12-2008 | 08:07 PM
nvm, just tried what i asked, its all good now, not gunna make it this weekend tho sorry, visiting west coast before school
