Lipo Problem
Old 07-17-2008, 01:31 PM
  #16
Registered User
Originally Posted by Flying Monkey
it was ho but not too hot to touch. Ive had Nimh batteries much much hotter. I never got to run on the battery lol. I was testing in my culdesac and was only a couple minutes into it and it happened. Luckily I was running without the body on it back and for and say the battery strap blow off...with the body on I might not have seen it and continued running to gawd knows what damage.
Boy I hope I dont have to trash this battery. If so I think ill sell my other 1 and stick to Nimh. These are my first lipo because they scare me a bit.
No... no... no dont go back to NiMh, I have never liked them they are expensive dont last and require way too much maintenance. Lipo is much easier to use plus you can use them more than once a day, you need to get used to the new technololgy thats all.
Loop&Roll is offline
Old 07-17-2008, 04:08 PM
  #17
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Originally Posted by rocketron
Your 7700 geared 19/86 in is simply pulling too many AMPs from the battery. This combination will tax even NiMH.
There is not a "low cost" lipo on the market that will not puff with this setup.
If you want to run a 7700 i would suggest dropping down the pinion about 5 teeth to begin with.
ok ill drop down to say a 16t for now (lowest i have) and order a 90t spur. that should bring me down I would think. Im huntng a 5700 motor but not having much luck in finding someone to buy this 7700 or trade for a 5700
Flying Monkey is offline
Old 07-17-2008, 04:42 PM
  #18
Doodad's Avatar
Originally Posted by rocket-mtrsprts
Unless the charger goes bad, or doesn't have regulating control like many cheaper chargers.
Very true. You do get what you pay for........unless it's Much More.
Doodad is offline
Old 08-03-2008, 08:53 AM
  #19
Trader Rating: 101 (100%+)
Default Max
I have experience with this issue. You have pulled more amps than that battery can deliver.In my opinion those lipos are overated on the c rating. The 7700 will pull around 70 amps when geared hard. I did back to back tests with a 3600 poly rc 12 c and it preformed about the same as the one you have. They will usually shut down before they puff up though.If it's swelled it's done and i would not use it and dispose of it right away. A low turn brushless needs a higher capacity battery with a c rating that lets you pull 100 amps or more to be safe.
latemodel13 is offline
Old 08-03-2008, 01:47 PM
  #20
JeromeK99's Avatar
I think you just had a rare bad pack.... it's done... no chance of it getting better..
I have used my Orion 3200 in my XXX-4 on a 9x2 mod and a 3.5 Novak Brushless.. many many times.. after practicing or racing the pack is not hot.. it's barely over the ambient temp outside...
As for NiMh.. i still like them and use them.. ya they have a bit more maintenance required.. not too big of a deal. i have all the gear.. I can usually get 8 months to a year out of a pack before they get moved to "practice only" or retired. I haven't had my LiPos for a year yet.. so I am very curious to see the lifespan. They cost 2-3 times more than a NiMh.... so.. the jury is still out!
Good luck and let us know what Orion says!
Jerome
JeromeK99 is offline
Old 08-03-2008, 04:47 PM
  #21
Default amp draw
I'm sorry i forgot to mention that in offroad it won't matter as you are not pulling alot of amps except for short bursts.
Old 08-04-2008, 11:16 AM
  #22
I got it back from orion today and they said they re-balanced it, charged and tested it and all is good. Ill try it out and see what happens. I trust their word, cause they could have just sent it back saying it was toast and I was SOL cause I had done somethign wrong or something. Im very impressed with their customer service cause turn around was really good considering the distance it had to travel.
Old 08-04-2008, 01:13 PM
  #23
JeromeK99's Avatar
Cool deal!
Jerome
