DX3R binding issue
How do you power the reciever when the bind plug is connected? Says to power the reciever and the LED will flash. No luck. If I plug the battery in to the aux it's a solid light. I'm either really dumb or have one of those duds. I can't get the rx to bind.
Any help would be appreciated. Thanks
I'm probably wrong but doesn't the battery plug go in the "battery" terminal and the bind plug into aux channel?
OK, I've read just about every page on this binding issue.
I am running lipo w/regulator for my receiver.
This is my 3rd receiver model (no issues with unbinding). I installed the binding plug as instructed, hooked up my battery and turn the unit on. A blinking LED indicates it is in binding mode. Selected a new model, went to bind, the transmitter acts like it is binding, here a small beep like it is bound but the LED is still blinking. The other 2 turned solid LED when it bound. I have tried this many times with the same result.
I have even reversed my battery connection, with same results. I took the binding plug out and plugged in the battery in the battery slot and it still blinks like it is in binding mode.
Has anyone have had this type of issue?
Thanks,
Tom
Thanks,
Tom
