Help needed  with trakpower v balancer >
Old 05-31-2008 | 02:05 PM
Boosta's Avatar
Default Help needed with trakpower v balancer
Hi All
i'm having trouble with my trakpower v balancer, when i connect it as per the instructions to my 4900 my charger comes up with connection break and won't charge??
i'm wondering if i need to plug the two charge leads into the top of the balance harness connectors which go into the battery pos and neg?
Boosta is offline
Old 05-31-2008 | 09:09 PM
P2's Avatar
P2
Connect the balancer to the charger, then connect the battery to balancer. Lights should flash indicating cell count. Then press the button for 3 seconds until the link light illuminates. Then start the charger
Your charger won't see the battery unless it's in link mode.
P2 is offline
Old 06-01-2008 | 07:49 AM
Boosta's Avatar
i tried that as per the instructions but my charger still comes up connection break??
Boosta is offline
Old 06-03-2008 | 08:16 PM
P2's Avatar
P2
Have you checked the 10A fuse? If that doesn't work I would send it back for a replacement.
P2 is offline
Old 06-04-2008 | 04:42 AM
theprocess's Avatar
Same thing happened to me. The fuse was the problem. Check to see if its blown, the tin will be broken/cracked.
theprocess is offline
Old 06-04-2008 | 07:16 PM
VooDooPH's Avatar
VooDooPH is offline
