3PKS question
I just picked up a 3PKS FASST system have a question regarding receiver capacitors. I've been using Spektrum for awhile and have always used the cap plugged into the receiver. Is this necessary/desirable with the 3PKS? If so, any reason I couldn't transfer the one from my Spektrum receiver?
In Spektrum at least, it's also used to alleviate voltage drops to the receiver. It keeps it from going into failsafe mode under heavy acceleration by keeping the voltage high enough.
Like you said, I don't think it would hurt to use...just don't like hooking up unnecessary equipment.
I use the FASST system in both 1/12 and touring car. Never had a problem. Try it without and see what happens.
You probably wouldn't see the problem in nitro, only in electric where the motor draw may be so great as to cause a voltage drop to the receiver.
