Futaba 4pk
#271
The c1 vs c2 is model specific. When you change models it will remember it just like all the other settings. What I have found is that when I switch from the 604 to the 603, I need to turn the radio off AFTER I switch and then turn it back on.
#273
I've troubles when using my 4PK with a Sanwa RZ servo (the one with the blue aluminium heatsink). This servo works with my M11(I've tried it again a few minutes ago)
When I go fast right then left, the servo makes a strange noise and becomes slow....after a few seconds it works ok and if I go full left the same thing happens.
Has anyone experienced this before???
Do I have to buy a Futaba servo?
#274
You need to take it out of high speed mode. Mine did the same thing. High speed mode is only for digital servos. I believe it is either is system menu or rx menu. I don't have my manual or radio near me.
#279
Held one in my hands today. Me no likey. Trigger's too close to the grip and doesn't have enough throw in either direction. Judging by a quick run through the menu and a once-over of the instructions, I don't think there is a single thing that this radio can't do. But it just doesn't feel right......it's that or maybe the fact my LHS wants an arm and a leg for it.
#280
#281
Got mine on friday.
I am.....was a diehard Hitec fan, but with the lack of Hitec even acknowledging 2.4ghz, I had to make the switch.
Last Futaba I owned was back in 1994 and that was the 3PJ, wow has this thing come a long way. Love it!
#284
Where was the batter voltage set in the fail safe?. You can adjust various points. Not sure if you were aware of that or not. I ran mine for 30 minutes in my GT2 without any problems at all.
#285
As one of the other guys said, I hope it is only a setting. If not I truely feel sorry for you.
I was starting to doubt buying a React and not waiting for the 4PK as I'm having trouble finding a second Rx.
But if I had the 4PK and I'd experienced the cut out again I recon I'd smash it.
