Radios that can control only selected model? >
Like Tree5Likes
  • 2 Post By DirkW
  • 1 Post By Roelof
  • 1 Post By billdelong
  • 1 Post By PDR
Old 06-10-2025 | 10:14 AM
Default Radios that can control only selected model?
Hello,
I believe Spektrum radios let you control only the selected model, even if you have multiple bound models powered on. Are there any other brands or radios that have that feature?
I have a flysky gt5 and a radiolink rc4gs. Both will control every bound receiver that has power at the same time.
I want to have multiple trucks powered up that are all bound to one transmitter and be able to control one at a time.
Thank you!
SparePartsBox is offline
Old 06-10-2025 | 10:22 AM
DirkW's Avatar
Sanwa radios can do the same, when people remember to set them to do it.
gigaplex and SparePartsBox like this.
DirkW is offline
Old 06-10-2025 | 12:49 PM
Roelof's Avatar
Futaba with S-FHSS receivers are not model sensitive, any model with an S-FHSS receiver (bound to that transmitter) can be operated from any other model if it is set to S-FHSS. The T-FHDD receivers are only reacting to that one memory model that it is linked to.
SparePartsBox likes this.
Roelof is offline
Old 06-11-2025 | 05:55 AM
FlySky Noble will only control the current model selected, though I don't recommend having multiple cars turned on at the same time.
billdelong is offline
Old 06-11-2025 | 09:02 PM
Thank you all! That gives me a few more options than just Spektrum.
Old 06-11-2025 | 10:37 PM
PDR's Avatar
PDR
For whomever this is useful, my reading of the NB4 manual is that "2 way" mode is required for model-receiver binding, but happy to admit I have not tested it extensively:
From the manual:
[AFHDS3 1 Way]: It features lower latency, allowing one transmitter to connect multiple receivers. It is applied when the model does not need any return data.
[AFHDS3 2 Way]: With the two-way return function, it can return feedback data from receivers and sensors and realize one transmitter to one receiver.
gigaplex likes this.
PDR is offline
