Team Exalt Phoenix slow >
Like Tree7Likes
Old 03-11-2025 | 12:30 PM
  #16
HOTROD716's Avatar
Originally Posted by River19
Interesting. I haven't tried an Exalt motor, but I did swap recently to one of their batteries, 4400mah 150 C and it is has done well for me. Holds punch longer than my Reedy batteries and "feels" a little livelier later in a heat than my ProTeks.
That being said, the spreadsheet snippet that RC10Nickquoted above has the New Wave motor I am running (I have 2 of them) and in dirt oval street stock that New Wave is outstanding and is holding it's own against the newer HW G4s etc,
When it comes to Motors it feels like there is some luck involved as well as making a selection and setup that matches your application well. I have a Motiv MCS in my 2wd clay car and I think the New Wave was stronger despite the testing showing the MCS being a little better numbers performer. And I completely blew up a Team Powers 13.5 recently so now I am on to a Rotor Ron motor.....we'll see......
The problem is many new motors, do not need too much timing. Have to find the sweet spot. I have a Fantom 13.5 Helix v2, that thing is torquey. Low timing numbers, around 43. I have a R1 17.5 v21hd, Sammy told me to put the timing to 50. That thing has been great also.
HOTROD716 is offline
Old 03-12-2025 | 04:23 AM
  #17
The Rotor Ron motor I added is a Fantom Helix set by Ron.......timing appears to be low to mid 40s from what I recall when I threw it on the analyzer. 3900 KV 30K rpm 5.5 amps unloaded......so we will see this weekend when I give it a go in the L1R.
I may back off the timing on the MCS.......we'll see.
The Team Powers failure was a QC challenge from what myself and others can tell. It is what it is.
River19 is offline
Old 03-12-2025 | 05:40 AM
  #18
If the battery is still relatively new, that’s why. Give it some time and report back. It may degrade to the point that it’s no different than the Reedy or the Protek. New batteries will always have an advantage for a little while.
River19 likes this.
revo_race is offline
Old 03-12-2025 | 06:17 AM
  #19
My 5200 I am selling is 2 years old, they are around 3.1 ohms/each. I would double check you cables, sounds like the charging cables might be getting old. I thought I had higher battery ohm reading on a battery, found out my cables were getting worn. I Charge and discharge at 30amps.
Cables are good. My Reedy 4800 90c reads 3.1/cell just like it has for the last 9 months with the same cables. Also always charge at 2c. That one will read 1.5/ cell right when it comes off the track.
HOTROD716 likes this.
Tmarsh34 is offline
Old 08-18-2025 | 09:15 AM
  #20
Originally Posted by toepush
Kevin Abbott owner of said "Exalt" formally known as head of "Trinity" before Horizon hobbies purchased them... Sole man responsible for the Trinity Slot Machine "1" motor, and the over priced stock motors. Interesting to see he's still carrying on old Trinity$ busine$$ plan$, and product$. The vintage saying is now confirmed true "Theres a sucker born every day" My 👒 off to you sir....
so true!
Kenny_G is offline
