Swapping out electronics (Removal tips?) >
Like Tree4Likes
  • 3 Post By Roelof
  • 1 Post By shortcut3d
Old 04-25-2024 | 11:33 PM
Default Swapping out electronics (Removal tips?)
Not sure if this is the best place to post this.
I’m switching from Sanwa to Futaba. Are there any tips for removing the receivers from 1/10 off road vehicles. The red 3M double sided tape is holding really strong. I don’t want to damage the receiver or scratch the electronics trays.
I’ll also be swapping out ESCs for my stock spec cars and have the same challenge.
shortcut3d is offline
Old 04-26-2024 | 12:03 AM
I use denatured alcohol or isopropyl alcohol. I let some drip around the base, and soak into the edges. Then i use something plastic to pry the esc/rx slightly, to get some more alcohol underneath. Works great !
Grega0121 is offline
Old 04-26-2024 | 01:02 AM
Roelof's Avatar
Warm it up with a hairdryer.
Bud, hunterdawg and staiguy like this.
Roelof is offline
Old 04-26-2024 | 07:13 AM
UrabusDenis's Avatar
I've recently had issues since buying some new doublesided tape, it's really strong - great at its job obviously! I even damaged the casing of a receiver trying to get it out of a nitro receiver box. I've found a nice small prying tool which does the job (from a kit for car bodywork/bumper repair) which I'll keep close from now on, but really anything with a wide L-shaped tip will work. Just be patient and don't use excessive force.
UrabusDenis is offline
Old 04-26-2024 | 12:57 PM
staiguy's Avatar
heat plus a plastic wedge/prying tool. Obviously you dont wanna pry it off, but slowly scrape away at the bottom. A little alcohol will help steady the user and clean up the sticky goopy residue from the tape.
staiguy is offline
Old 04-26-2024 | 06:16 PM
MonkeyCmonkeyDo's Avatar
I use a red handle flat xacto knife. It's rectangle shape and has a flat head on it but a sharp edge like an xacto knife.
MonkeyCmonkeyDo is offline
Old 04-26-2024 | 06:18 PM
T
they are called chisel blades.
Old 04-29-2024 | 12:23 PM
Alcohol worked wonders to loosen the servo tape. I didn’t want to apply heat to the ESC and receivers. I also remembered I have plastic pry tools for removing Apple device screens, and automotive interior plug removal tools. The combination worked well across 22x-4, 22SCT 5.0, and B6.4s.
Word of caution. The alcohol turns 3M red label double sided stick tape into a gummy mess while it’s still wet. I ended up waiting for it to dry before removing the left over tape residue from the mating surfaces. Then a final cleaning with rubbing alcohol on a lint free cloth.
Thanks all!
UrabusDenis likes this.
Old 06-18-2024 | 06:09 PM
I will usually take a length of fishing line , wrap it around the base of the Rx ,ESC, or servo and pull it . Almost like tying a knot around it. It will get under the case and split the tape.
OldNCrusty is offline
