14Likes
Can I run a fan and transponder into a splitter?
I have a 3 channel radio but need 4 things plugged in. Can I run the transponder and motor fan into a splitter on the 3rd channel?
Not sure I've seen a 3-channel receiver with only 3 ports, but yeah a splitter will work fine. Just make sure to use a decent quality one and watch for it getting snagged or working loose.
Some motor fans are happy to work off the battery directly, so consider that option too.
There is absolutely no reason for the motor fan to be plugged in to the ESC (where do you plug in the ESC fan?), and both ports are supplied by the same BEC anyway.
Yes,.4 way servo splitter in Toys & Hobbies for sale | eBay As long as other plugins aren't signal controlled. You can still use 3rd channel aux and other pug-ins are only dc powered.
Just a simple Y cable is needed
Thanks everyone 🙂
Also many people put high timing in their stock motors and gear them to the moon.
