Like Tree7Likes
Sanwa m17 ?
Old 03-30-2024, 07:31 PM
  #16
gigaplex's Avatar
Originally Posted by lbsnoopy
yea , I don’t know , that’s all. Changed was my epa’s on throttle with the car that has the new 492i , so I then went to the car with the 482 and changed those settings and everything started working as it should . I tried the lipo cutoff settings first thing this morning , from 3.4 to 3.2 and that changed nothing, made sure I was 6.0 on the bec , nothing , put the 492i in when it got here from usps , nothing, played with the epa’s and everything started to work .
What did you change the EPA from and to? And did you calibrate the ESC each time you changed it?
gigaplex is offline
Old 03-30-2024, 08:13 PM
  #17
lbsnoopy's Avatar
Trader Rating: 6 (88%+)
Default Reply
the th base setting in throttle was at 0%and I ran it up to 115% , the esc , I only changed the lipo cutoff to 3.2 from 3.4 , but I had done that before I got the new receivers in the mail today .
lbsnoopy is offline
Old 03-30-2024, 08:19 PM
  #18
lbsnoopy's Avatar
Default Reply
This also gave me more throttle response , before that the car was not responding till I was at half of a trigger pull , now it is instant response on the pull .
lbsnoopy is offline
Old 03-30-2024, 08:54 PM
  #19
gigaplex's Avatar
SUB-T is sub trim (neutral point), not EPA. Sounds like your ESC calibration is way out.
SUB-T should be 0. EPA-H should be 100%. EPA-B should be 100%. RATE-B should also be 100%. Then calibrate the ESC. I'm guessing your receiver is connecting just fine and it's your ESC that's refusing to arm because it's failing to find a neutral signal due to an incorrect calibration.
lbsnoopy likes this.
gigaplex is offline
Old 03-30-2024, 09:05 PM
  #20
lbsnoopy's Avatar
Default Reply
when I put the sub-T back to 0 I loose throttle response.
lbsnoopy is offline
Old 03-30-2024, 09:29 PM
  #21
lbsnoopy's Avatar
Default ??
So , I should recalibrate the esc ?
lbsnoopy is offline
Old 03-30-2024, 09:42 PM
  #22
lbsnoopy's Avatar
Default THNKU
THNKU gigaplex ! That’s what was needed , to recalibrate my esc , on both cars , total brain fart on my part .
gigaplex likes this.
lbsnoopy is offline
