5Likes
Motor shaft marking
Just picked up a used Reedy motor - it has the numbers 275 on the pinion flat. What is this?
Motor is supposed to be a 7.5t - I'm hoping it isn't a 27.5t !
Also, what's the best way to clean this motor thoroughly? Same for the ESC I've got with it, there's a sandy/muddy residue on it.
Electrical spray for the motor and to get excess stuff off the ESC, and if there's still divided stubborn stuff on the ESC, isopropyl alcohol and a toothbrush.
275 rotor
That part number is how you tell what rotor is in the motor, as you can change them to tweak how the motor performs. I wanna say I ran a softer 272 rotor in my 2wd buggy when I ran the M3 reedys. As an example.
Do you know what physically changes between the rotors?
The rotor in a brushless motor is just magnets though right? Looking at the link you posted - 275 isn't there - each number though seems to refer to a number of turns - maybe that's just the default rotor for the motor?
The number has nothing to do with the number of turns of the stator.
Their link took me here. Part number is 275. Dimensions are 12.5 outer diameter, 5.0 inner diameter, 25.3 length.
275 rotor
I'm going to be running it in 1/10th modified stadium truck - anything I should be aware of? What would one expect from an older motor?
Should be absolutely fine for mod truck. Just lookup the gearing chart in the manual. Rebuilding the ball diff and breaking it in for 20 min and setting your slipper right is all you'll have to worry about. Mod motors will last for years since they dont run as hot as stock motors.
Depending on your skill level, and if the motor is still good, it should be pretty competitive for you. I would get some electric motor cleaner and take the motor apart to clean it. Also, make sure to lube the bearings really good.
