What amp to charge 1S lipo battery for transmitter use ? >
Like Tree5Likes
  • 1 Post By gigaplex
  • 2 Post By Roelof
  • 1 Post By glennhl
Old 12-14-2023, 12:11 AM
Default What amp to charge 1S lipo battery for transmitter use ?
Hi all,
I am using a SkyRC T200 charger.
Please advice what ampere do I use, to charge the above photo battery ?
foosoomin is offline
Old 12-14-2023, 12:27 AM
gigaplex's Avatar
3.2A
glennhl likes this.
gigaplex is offline
Old 12-14-2023, 12:39 AM
SkyRC just email reply me, the answer is 1C
Old 12-14-2023, 12:58 AM
Roelof's Avatar
If you charge it when placed in the transmitter I would not go higher than 2A.
Goof and oldfool like this.
Roelof is offline
Old 12-14-2023, 03:02 AM
gigaplex's Avatar
Which is 3.2A
Goof likes this.
gigaplex is offline
Old 12-14-2023, 07:07 AM
Zerodefect's Avatar
1.5a.
Zerodefect is offline
Old 12-14-2023, 07:53 AM
DirkW's Avatar
Definitely not above 1C, but since there's nothing to gain from higher amps here and these cells are not made for any real loads, I'd probably use even less than that.
DirkW is offline
Old 12-14-2023, 11:19 AM
Trader Rating: 16 (100%+)
I always charge my transmitter pack at 1C. I have a 2500 mah battery, so that is 2.5 amps. However, I never charge to full charge (8.4 volts), normally stop around 8.1 to 8.2 volts because it's a Lipo. You can't leave a Lipo fully charged for long periods or it can puff.
glennhl is offline
Old 12-14-2023, 10:44 PM
I charged the battery at 3amp yesterday, no issue
Old 12-15-2023, 12:16 PM
Something like that I charge at less than 1 amp. Maybe 500mAh. Because I want all the mAh I can stuff in it. And there's no rush so I can spend the day charging it.
Sabin is offline
Old 12-15-2023, 07:28 PM
staiguy's Avatar
30a up, 30a down, 30a up for maximum transmitter speed
staiguy is offline
Old 12-16-2023, 08:49 AM
I read this and laughed and laughed, loved it. But for those that don't know it's humor, please put a smiley face after it. Can you imagine if some poor soul took you serious? There would be a basement on fire somewhere!
staiguy likes this.
glennhl is offline
Old 12-16-2023, 10:27 PM
Geezatec's Avatar
Pg13 in manual. Lipo 3.7v 3200mah. 3.2amps enter, INC/DEC 1S enter, then Start/Enter. Telling you the true, I havent seen 1S lipo the hi on mah. maybe 2000-2200mah.
Geezatec is offline
