Like Tree22Likes
Product Comparison
Old 12-22-2023 | 07:54 AM
  #31
OffRoadJunkie's Avatar
Originally Posted by Cinnabun
the SP5 or the specR2?
The SP5. I haven't had a chance to get my hands on an R2 yet.
OffRoadJunkie is offline
Old 12-22-2023 | 11:17 PM
  #32
I finished editing the video, for the SP5. I will post it tomorrow. The rotor, on that motor, is right there with the Certified Slot Machine, at 1754 Gaus. Heads up, if you would like to purchase that SP5 motor, I just posted it for sale in the "For Sale/Trade" Forum. I have it listed for $99 but make me an offer.
petersen114 and shortcut3d like this.
Old 12-26-2023 | 12:20 AM
  #33
Sorry for taking so long to get it posted. Computer kept freezing up.
https://m.youtube.com/watch?v=2O5Pgd...LjUgbW90b3I%3D
birdapi likes this.
Old 01-16-2024 | 03:55 PM
  #34
I know there has to be more guys out there regularly testing and/or comparing RC products.
Tekin Gen4-R2 Elite testing results.
https://youtu.be/qK7tY1VcQTg
Cinnabun likes this.
Old 01-17-2024 | 09:22 AM
  #35
Sorry, but I have to share this.
I just tested a Surpass rotor that was the highest ROAR approved rotor I have tested yet.
N - 1755
S - 1787
Avg - 1771
What's the highest you guys have seen in a ROAR approved motor? This got me really curious on what's out there.
jo_er86 likes this.
Old 01-17-2024 | 05:53 PM
  #36
I watched your video. This motor is going to be great in 2wd buggy with the torque numbers. Should be able to gear it to the moon.
OffRoadJunkie likes this.
Cinnabun is offline
Old 02-03-2024 | 02:33 PM
  #37
Default Reedy Sonic 540-SP5 17.5T
I picked up a Reedy SP5 17.5T to go in my AE RC10B7 because the Horizon Hobby Trinity Slot Machine exchange hasn’t happened for the certified motors. I did the works, full Monty, certified treatment to the Reedy SP5 with Boca Orange Seal ABEC7 ceramic bearings and Reedy titanium screw kit. So I’m sharing couple more data points for the Reedy SP5.
The Trinity Slot Machine 17.5T was brand new (cracked the seal today) and was used as the slave motor for the load test. The tests were run on a Hobby Wing Tunalyzer off a 900W server power supply because my batteries are all in storage mode. I’ve noticed that the power supply reads differently than a 130C 2S battery. Usually a higher amp draw, but comparing within the test set it doesn’t matter.
Observations
  • The SP5 is timed 10 degrees less than the Slot Machine Certified out of the box.
  • Adding approximately 3 degrees more timing from 40.6 degrees only added 0.4A. Suggests that there is more headroom.
  • The fully blinged out (“works”) SP5 put out as much KV as the Slot Machine with 7 degrees less timing and a full one amp draw less making the SP5 much more efficient.
  • The works SP5 put out about 80KV more at .26A less.
  • Under load stock vs works was only slightly better KV.
  • Boca Bearing Orange Seal AF required break-in before the improvements started to appear.
Reedy SP5 17.5T
Out of the box:
​4.42A
2880KV
40.6 degrees
Adjusted to sweet spot based on the Internet
4.86A
2946KV
43.4 degrees
Load:
10.65A
2717KV
43.1 degrees
Works:
4.60A
3029KV
43.7 degrees
Works Load:
10.65A
2778KV
43.3 degrees
Slot Machine Certified 17.5T
Tunalyzer:
5.60A
3049KV
51.2 degrees
Motolyser printout:
3.49A
22630RPM
3059KV
50.6 degrees
shortcut3d is offline
Old 02-03-2024 | 04:46 PM
  #38
MonkeyCmonkeyDo's Avatar
I'd like to see a surpass v4s compared to a v6 or a newer than v4s surpass motor.
those and the hobbywing v10 motors.
Ty
D
MonkeyCmonkeyDo is offline
Old 02-03-2024 | 04:47 PM
  #39
The sp5 motor I'm under the impression isn't much of an improvement over the s+ series. Intrested in a comparison between those 2 as well.
d
Old 02-05-2024 | 12:56 PM
  #40
Ty
D
d
It would only be a good comparison if they were new. It might be pretty hard to find a new S+. If someone was willing to send me motors for testing, I would be more than happy to do it. From what I have seen, the newer motors are much better than the older ones.
I'm currently working on a new device to help better compare motors. Once I get it finished, I'll be testing more motors. I have had a lot of requests to test the Maclan, Muchmore, and Team Powers. I haven't decided which one I want to do first.
I tested the Hobbywing V10 G4 about 3 months ago.
https://youtu.be/L-9bAnVzTD8
HOTROD716 and MonkeyCmonkeyDo like this.
Old 02-06-2024 | 08:30 AM
  #41
HOTROD716's Avatar
I would vote for the team powers one. From my perspective, those team powers have a lot of TQ.
HOTROD716 is offline
Old 02-15-2025 | 07:39 PM
  #42
Are you referring to these two motors? Are they both ROAR approved?
I just ran a test on the Hobbywing G4. It was not impressive. What really put a bad taste in my mouth is how lose the windings were. I'm sure it's not like that with all, but you have to expect that mine was not the only one out there like it. It is a competitive motor, but due to how popular it is, I was expecting more.
how about the G4R? Any better than the G4? How does it compare to the Surpass Rocket V6?
Associated1515 is offline
Old 02-15-2025 | 07:41 PM
  #43
I've used the team powers and wasn't that impressed. I'm interested in the new V5S. But thw regular Actinium V5 Gauss rating was very low compared to the Surpass. I believe the team powers Gauss rating was about 1670/1680 and the surpass ranked near the top with around 1740 Gauss. The surpass motor allows you to gear up a tooth or two since the torque is insane and for the price you can't go wrong
Old 02-18-2025 | 04:17 PM
  #44
The G4R has must more torque than the G4. The G4R has a higher RPM, unloaded, but the V6 has a lot more torque. Racers are adding 2 more teeth to a V6, over G4R. However, on a wide-open track, the G4R can hold it's own.
