Like Tree57Likes
"Load Master"
Old 03-07-2024 | 05:26 PM
  #106
Sanchez's Avatar
Exalt's motor load test stand looks suspiciously similar to the load master: https://teamexalt.com/motor-load-test-stand-exa9312/
STLNLST and OffRoadJunkie like this.
Sanchez is offline
Old 03-07-2024 | 05:56 PM
  #107
OffRoadJunkie's Avatar
It probably is. He wholesales his products to many different companies.
OffRoadJunkie is offline
Old 03-07-2024 | 06:46 PM
  #108
trilerian's Avatar
While I do some OEM for DRC, the Exalt product is not mine, nor made by me.
trilerian is offline
Old 03-07-2024 | 06:53 PM
  #109
Copy write issue? What a bunch of losers! There is not doubt that they reverse engineered your design. They suck so bad!!!
TOM MAR likes this.
Old 03-07-2024 | 07:06 PM
  #110
trilerian's Avatar
While I appreciate your support, my product is not covered under any patents or copyrights. Point of fact, you can go through this thread and get all the info to make your own. I only hope that those who want one will still be enticed by all the pretty colors I offer! And the amazing customer support I provide! Yes, I am biased, but I do give great support.
STLNLST, PDR, TOM MAR and 1 others like this.
Old 03-07-2024 | 08:02 PM
  #111
PDR's Avatar
PDR
Note that as opposed to a patent or trademark, copyright exists automatically (in most countries, but not all). No need to claim or register it. Regardless, trilerian has publicly expressed eagerness to share, for which many of us are grateful . It's getting into nuance, but copyright covers the expression of an idea, not the idea itself.
None of that stops people from having contempt for those who abuse the intent of that.
trilerian, TOM MAR and gigaplex like this.
PDR is offline
Old 03-08-2024 | 12:49 AM
  #112
Roelof's Avatar
The question is if the costs of a patent can bring up enough money, within the RC world that is difficult.
My idea of an FDR meter had many follow ups by other home brewers and recently a true MR33 commercial product. I had interests by Muchmore but at the end they went up another way to keep control on an equal performance. For me it still gives me a proud feeling, for sure with the knowledge 3 cheating ENS top names were send home. And of course the people around me know I started this.
Alexv2024 likes this.
Roelof is online now
Old 03-08-2024 | 04:28 AM
  #113
gigaplex's Avatar
In the case of the load master it wouldn't be patentable anyway as there's too much prior art.
gigaplex is offline
Old 03-08-2024 | 11:23 AM
  #114
lutach's Avatar
I wish I was still selling Electronic Components, I could've helped you save a lot of money getting those resistors and what ever else component wise you require. I always think about getting back in, but I think I took a challange that might be impossible lol. Like some have pointed out, your product is protected since it is published. If I was that other company, I would contact you ASAP and work things out. Example, a certain person in Israel copied a design from a person in the U.K., but the person spoke with the original designer and they came to an agreement. If you need any electronic components send me a PM and I'll see what I can do since I still have contacts of my suppliers.
lutach is offline
Old 07-23-2024 | 04:46 PM
  #115
I'm looking at testing a 25.5 and was wondering what turn motor I should use for a load ?
Friulimotosport is offline
Old 07-23-2024 | 04:55 PM
  #116
trilerian's Avatar
I always suggest using the same size slave as the motor you are testing. But a 21.5 or 17.5 will still work, it will just put slightly less load on the test motor.
OffRoadJunkie likes this.
Old 07-23-2024 | 05:13 PM
  #117
Is their an advantage of a lower over a higher load?
Old 07-23-2024 | 05:40 PM
  #118
trilerian's Avatar
A higher load will bring out deficiencies easier, and sometimes make the data easier to see where the divisions are. But take into mind that a higher load is harder on the motor analyzer you are using. Specifically the Tunalyzer will “stall out” with higher loads. That said I wouldn’t worry about that with a 25.5, just use another 25.5.
Old 07-23-2024 | 06:30 PM
  #119
Thanks for the fast response
