Like Tree57Likes
"Load Master"
Old 07-09-2023 | 08:29 PM
  #46
trilerian's Avatar
Originally Posted by gigaplex
Or the other side, the material looks pretty thin. Might need beefing up.
If I need to I guess I can. But this is the same as the current mount with the thinnest section being 2.75mm. So far there have not been issues. But, I suppose this could be a weak spot.
The top is a separate body as well, and will be mounted with screws. Maybe I should shave 0.5mm off the back side though just to make sure it doesn't bind. 15 hour print just for it to not align would be annoying...
trilerian is offline
Old 07-09-2023 | 09:55 PM
  #47
PDR's Avatar
PDR
I sometimes print smaller subsections of things like this to avoid disappointments
Got too many printers now - I bought a chonky one to print fasterly and biggerly.
trilerian likes this.
PDR is offline
Old 07-12-2023 | 03:00 PM
  #48
trilerian's Avatar
Hobbywing Tunalyser came in today.
Here is a photo with a Slot Machine 13.5 pulling almost 20 amps.
I will say the Tunalyser is a pretty nice piece of equipment.
gigaplex likes this.
Old 07-12-2023 | 04:08 PM
  #49
trilerian's Avatar
And here is a pic on an ESC running my telemetry unit.
The harness coming off the driven motor is for testing with timing. Doesn't need to be on the actual unit.
Old 07-13-2023 | 11:31 AM
  #50
trilerian's Avatar
Update on Timing. I have proof of concept for measuring timing on one phase. I am attaching pic of a function generator setup to output 2 square waves at 303hz and phase shifted 45*. Then with the arduino I am measuring the phase shift on external interrupt pins. I am printing the output to the serial monitor for now, printed variables are frequency, RPM, and Timing.
Bsthetech likes this.
Old 07-14-2023 | 06:18 PM
  #51
trilerian's Avatar
For a clean look, install your esc on top of the mount.
Hobbywing Just Stock pictured with Sanwa rx.
Old 07-14-2023 | 07:26 PM
  #52
Kraig's Avatar
Super Moderator
Looks good! Did you make that coupler that connects the motors together yourself?
Kraig is offline
Old 07-14-2023 | 08:00 PM
  #53
trilerian's Avatar
I did not. Machining metal is out of my scope. I really need someone who can do that...
Anyway, that is from Amazon, 3.17 - 3.17mm coupler.
https://www.amazon.com/dp/B08QFNDP3H...t_details&th=1
Old 07-14-2023 | 09:31 PM
  #54
trilerian's Avatar
More testing with timing tonight. It is getting better, lol. Below are some pics that show a Slot Machine 13.5 @ 40* on the can and the readout from my code. Then @ 45* on the can with readout. Finally I put an R1 v21s 21.5 @40 on the can and the readout. Now R1 always read lower on the can by 4-5*. And my Motolyser confirms that. Now there are caveats... The pwm gets in the way of the bemf reading so I have only been able to read at full throttle. Anything less and all the readings are way off. I'm still working on it, lol. But this is progress!
Old 07-14-2023 | 10:31 PM
  #55
gigaplex's Avatar
The SkyRC style analyers can only measure timing at full throttle as well. I'd say that's an acceptable limitation.
gigaplex is offline
Old 07-30-2023 | 09:43 PM
  #56
trilerian's Avatar
I took a turn trying something else this evening. I hooked my telemetry unit up to the MiniPro flywheel unit and ran a run using my telemetry unit. I had to tweak the code a bit to use 2 hall effect sensors instead of just one for RPM. I need to add the third, I'll work on that later. But for a first attempt I am pleased with the outcome. This is a Slot Machine 21.5. It compares pretty well to the MiniPro output with one big caveat. My numbers don't go above 65% efficiency. So there is that...
For anyone curious, I redirected serial output to a terminal monitor called RealTerm. I then took my readings and added them into excel and created formulas for Torque and Power. My initial sample rate is 10hz. I was having issues going above that due to my voltage and current averages interfering with the rpm. In order to proceed I am going to have to completely rewrite the code for faster sample rates. My original telemetry unit doesn't need to update faster than once per second, or 1 hz.
EDIT: Looks like I didn’t start the data quite right on the graph. I just need to grab the first values, so the power at 0 rpm is 0. Torque will also be zero, nature of the flywheel…
Old 07-30-2023 | 11:14 PM
  #57
gigaplex's Avatar
65% peak efficiency sounds like it's in the right ballpark. Most dyno results of RC motors I've seen are in the 50-70 range.
gigaplex is offline
Old 08-03-2023 | 06:53 PM
  #58
trilerian's Avatar
I had a request to add "KV" to the readings. I took this chance to revise the software a bit. I also changed from reading the high low pulse for rpm to using hardware interrupts. Also I cleaned it up a bit to be able to run both my telemetry module and a motor analyzer in tandem with each other. Here are some pics of running the SkyRC unit with my telemetry module. I also am comparing to my 5.5 digit bench dmm to show that my telemetry unit is more accurate for voltage, and KV is dependent on voltage.
PDR likes this.
Old 08-05-2023 | 11:20 PM
  #59
trilerian's Avatar
I had a motolyser shootout last night and tonight. I took an R1 21.5 and a Trinity 13.5 and ran each motor at 30, 35, 40, 45, 50 degrees timing. I ran each of these on the SkyRC, Tunalyzer, Motolyser, and my telemetry unit. I also ran each test unloaded and then loaded with my Load Master using the 2 ohm resistor bank. This was interesting, and took absolutely forever... my conclusions are that the readings are all over the place, lol.
So caveats:
The Hobbywing Tunalyzer and the Trinity Motolyser both use 7.4v for the test voltage. To try to get close to the same on each test, I used my variable voltage power supply as a power source dialed to 7.75v. So there is a slight difference with the SkyRC and my unit for voltage.
Also, with the 13.5 on my telemetry unit with an esc, at 30* timing and unloaded, the current is actually higher than at 35*. I spent a good amount of time re testing and verifying this. I also ran my telemetry unit in tandem to make sure it was reading correctly. When using a analyser to drive the motor, it looks good. But when using an esc this behavior pops up. I got nothing... I tried both a Hobbywing Juststock, and an XR10 pro gen 1. Unfortunately I can't exactly test a motorlyser and an esc in tandem...
Anyway, instead of putting a ton of pics on here, this time I am just linking to my github repository. https://github.com/trilerian/Dyno-Results
EDIT:
Added graphs with Current vs KV.
Old 08-08-2023 | 07:43 PM
  #60
trilerian's Avatar
Case redesigns to allow for a little cooling of the motors.
OffRoadJunkie likes this.
