Like Tree2Likes
  • 2 Post By Roelof
Hobbywing esc
Old 06-15-2023, 01:22 AM
Default Hobbywing esc
Hi. I bought a hobbywing pro stock 1s new off ebay.
It came in a plain hobbywing motor box but it says 2s on the esc case. The seller says its a factory drivers version. Do they come like this? Thanks
jeremy444 is offline
Old 06-15-2023, 03:36 AM
Roelof's Avatar
The info page on the Hobbywing is very clear:
XeRun XR10 Stock Spec 1S (hobbywing.com)
So yes, you got a wrong ESC I think. And the mention of a very special team driver edition I doubt that. Not that they do not excist because I do believe they do but I know some shop owners who like to mention that a lot with the used stuff they sell.
choisan and gigaplex like this.
Roelof is offline
Old 06-15-2023, 05:25 AM
gigaplex's Avatar
Would a factory driver's version be ROAR et al legal? From the homologation form:
  • ESCs can be submitted at any time, but they must be approved AND available at retail locations 30 days before a ROAR event to be used in competition
  • Any model ESC that has an unsubmitted, unapproved companion model that is indistinguishable by any means other than its label, will not qualify for approval.
gigaplex is offline
Old 06-15-2023, 06:19 AM
Roelof's Avatar
What contains the roar approval and is that needed for modified racing?
In case of a blinky ESC, what is checked? One thing some racers kick on are the specs of the used FET's, you can use better FET's than normally used in production.
Roelof is offline
Old 06-15-2023, 01:44 PM
gigaplex's Avatar
If the hardware or firmware is of a version that is not approved, it's illegal for blinky. Don't know about modified. All firmware updates need recertification. Pretty sure most companies already break that rule, but anyway...
Couple more points on the homologation form that are of interest:
  • New software versions for programmable ESCs must be approved. Speed controls using software that is not approved will be deemed ineligible for competition and any results disqualified.
  • As a company principal, I certify that all the above information is accurate and that the ESC being submitted is a production unit, identical to those that will be available to team drivers, and through the retail market. I understand that a violation of these rules will result in a minimum one-year suspension from the ROAR competition.
http://www.roarracing.com/downloads/ROAR_ESC_FORM.pdf
gigaplex is offline
