Broken antenna wire
Old 04-16-2023 | 01:14 PM
Default Broken antenna wire
If I solder a Broken antenna wire will it work like it was or will it not make a difference and be only as good uo to the break
rekim is offline
Old 04-16-2023 | 02:27 PM
Roelof's Avatar
What kind of antenna?
An old 27/40/75MHz receiver has a simple wire, you can solder the pieces together again but it is better to replace the whole antenna for a fresh wire.
The same counts vor a 2.4GHz antana made of a simple wire.
2.4GHz antenna's based on a coaxial cable just need a 3cm (from the shielding) stripped end piece. to be a new antenna again. If it is plugged to the receiver board you can find new antenna's from many brands.
Roelof is online now
Old 04-16-2023 | 03:47 PM
its from a traxxas trx4 receiver. i accidentally ripped it in half
rekim is offline
