Case/storage for 2 transmitters >
Old 09-17-2022 | 01:16 PM
R/C Tech Elite Member
Default Case/storage for 2 transmitters
Anyone have a decent bag that works for 2 radios? Want to be able to bring my 10px and my daughter’s 3pv and keep them in the same bag.
Jaredf is offline
Old 09-17-2022 | 02:00 PM
Roelof's Avatar
Go to a shop where they sell theater/disco equipment. They do sell cases in all kind of dimensions with cube tile foam you can pull out to any shape.
Roelof is offline
Old 09-17-2022 | 02:50 PM
Go to a camera shop, gun store or a shop like Cabela’s. Buy a pelican like case with pick and pluck foam. B&H photo is a good place for mail order.
https://www.bhphotovideo.com/c/buy/c...proof/ci/16460
malkiy is offline
Old 09-18-2022 | 11:08 AM
I use this case here:
https://www.harborfreight.com/18-in-...ase-69318.html
It comes with pull/pick foam to customize your storage needs where I fit 2 radios, plus my power supply and iCharger 406 duo
First radio is a HiTec Lynx 4S and second radio is a FS Noble
billdelong is offline
Old 09-18-2022 | 11:13 AM
the rc guy's Avatar
I use a older Hocket bag..A goalies will hold 5 east
the rc guy is offline
Old 09-18-2022 | 02:09 PM
I'm going to recommended the Harbor freight Apache line.
I've had one for about a year, I keep my radio, charger, batteries, charging leads, and ESC programmer in mine. It's been dropped, stood on, kicked, etc. No issues ever.
skife is offline
Old 09-19-2022 | 09:50 AM
I much prefer using Kaizen foam or similar. Holds up much better than pluck and pull and the shape is more precise if you do a good job cutting.
biz77 is offline
Old 09-20-2022 | 04:09 PM
You can find yoga/pilates/exercise mats that are closed cell foam and they came out cheaper or did. Hot knives are cheap online.
*edit - the mat I have is much denser than the light gray standard foam for cases. I imagine it is closed cell to repel moisture/sweat.
performula is offline
Old 09-23-2022 | 07:10 PM
soulcoma's Avatar
Harbor Freight and get the case that would fit. then pluck the foam as needed to fit them nicely
soulcoma is offline
Old 09-24-2022 | 06:11 AM
elk
I find that Harbor Freight pick-n-pull foam falls apart easily and has to be glued. Their knockoff Pelican cases work well otherwise.
elk is offline
Old 09-24-2022 | 06:22 AM
1995 Monster T's Avatar
I have a hobbico deluxe transmitter case.
1995 Monster T is offline
Old 09-25-2022 | 07:50 AM
that is the issue I had with the protek hard case with pick-n-pull. I got both my radios in there perfect and as soon as I pull them out the first time the foam just breaks apart into all the smallest pieces. Maybe I didn’t pick it apart properly, but regardless not a huge fan
Jaredf is offline
