old guy back with ? servos >
Like Tree1Likes
  • 1 Post By sosidge
Old 04-16-2022 | 06:19 PM
Default old guy back with ? servos
just beginning to returm to hobby. working on losi minis . i have old servos from 1/12 pan cars. will these work with new radio/reciever sets?
goonride49 is offline
Old 04-19-2022 | 11:15 AM
If they're digital you'll be fine. Analog servos can burn out if run with some of the newer receivers unless you can set them to analog mode.
anthonyscardina is offline
Old 04-20-2022 | 06:18 AM
sosidge's Avatar
Not really true, the issue is not digital/analogue, the issue is HRS/SSR/etc. aka high frequency settings on the radio. And these are switched on or off at the transmitter, not the receiver.
I'm willing to be corrected on this but I'm not aware of any radios that CAN'T be run in "standard" mode for analogue servos.
sosidge is offline
Old 04-20-2022 | 07:55 AM
Roelof's Avatar
Nope, you are wrong. Analog servo's need to have a framerate of at least 16msec, digital servo's using the same 1.5msec center pulse width will work up to 333Hz framerate. Like the digital servo setting in Futaba transmitter uses but also the older Futaba HRS has a 5.5msec framerate as also the Sprectrum DX pro transmitters can go up to 5.5msec framerate.
SR, SSR, SXR, SBUS and several other very high speed modes use a different pulse width (SBUS even a digital serial code) and will only work with compatible servo's.
Roelof is offline
Old 04-20-2022 | 08:25 AM
sosidge's Avatar
How am I wrong in saying that an analogue servo can still be run on "normal" response speed from the transmitter?
Why do Futaba still sell analogue servos if they don't work with their radios?
gigaplex likes this.
sosidge is offline
Old 04-20-2022 | 09:08 AM
Roelof's Avatar
If I did read it right you say the burnouts with analog servo's is not about analog/digital but super high response sytems.. Again, it is about the analog/digital setting because in analog mode the servo signal is forced to 16msec while digital (depending the transmitter) can go as low to 3msec (333Hz) with which analog servo's will not work.
Roelof is offline
Old 04-20-2022 | 06:41 PM
I was trying to stay out of the nitty gritty, the point was to be careful with analog servos on modern radio systems.
Old 04-20-2022 | 07:46 PM
gigaplex's Avatar
Except it is about the protocol speed. You can burn out a digital servo too if you set the protocol incorrectly.
gigaplex is offline
