Power supply recommendations please >
Like Tree11Likes
  • 5 Post By glennhl
  • 1 Post By ray4624
  • 1 Post By Roelof
  • 1 Post By rcbuggy88
  • 3 Post By rustyus
Old 08-10-2021 | 04:17 PM
Default Power supply recommendations please
Looking for recommendations on a power supply.
I have a icharger 406 duo and charge 2-4 cells.
thanks
Mike
MikeMM is offline
Old 08-10-2021 | 05:02 PM
RL Power Supplies
glennhl is offline
Old 08-10-2021 | 05:24 PM
Originally Posted by glennhl
RL Power Supplies
I second this.
I think it’s the cheapest you’ll find these retrofitted $25 power supplies for haha.
I went with the mini for my 406.
MikeMM likes this.
ray4624 is offline
Old 08-11-2021 | 12:38 AM
Roelof's Avatar
power supply?
Icharger power supply
question about this power supply for a new 406 charger
Charger Power Supplies
Picking up a good quality PSU
And many more topics to be found......
MikeMM likes this.
Roelof is offline
Old 08-11-2021 | 10:08 AM
Thanks for all the info!
MikeMM is offline
Old 08-17-2021 | 04:51 PM
it really depends on how must power you want your icharger 406 to have. The icharger needs a 24volt power supply to get the maximum rated power out of it. But 90% of all racers just use a standard $30 12 volt computer server converted power supply to power their i chargers. The 12 volt power supply is the cheepest option but will only give the i charger about 500ish watts of power which should be enough for most 2-4cell charging needs .
riceball777 is offline
Old 08-17-2021 | 04:58 PM
If you only need 12V, RL is good to go. Michaels Hobbies in FLA sells an exact version of it too.
Silverbullet555 is offline
Old 08-17-2021 | 09:12 PM
If you want something premade, RL is fine, but they definitely are pricing their power supplies very high. Here is what they are using
https://www.ebay.com/itm/32441508809...YAAOSwWSxf1RS4
If you are comfortable soldering bullets, you can just do that, plus short 2 pins to make it power on when plugged in, and you'll have the same exact power supply as RL for 1/5 of the price...
BaconRaygun likes this.
rcbuggy88 is offline
Old 08-19-2021 | 03:49 AM
rustyus's Avatar
Those server power supplies, that are linked, are sold out, but can be found at the usual places. I picked one up new, years ago on Amazon, for something like $15. Simplest (IMO) power supply to covert... one soldered jumper wire needed to be able to turn on unit.
Goof, glennhl and BaconRaygun like this.
rustyus is offline
Old 08-19-2021 | 03:41 PM
HOTROD716's Avatar
I use 2 of the hp server to make 24v. No issues in using 1 or 2 chargers off of it.
HOTROD716 is offline
Old 08-31-2021 | 10:22 AM
Buckyaga's Avatar
R/C Tech Elite Member
Do you have a repo for the 3d printed caps?
I am going to need to get one of those made for mine, look pretty cool.
Buckyaga is offline
Old 09-03-2021 | 06:03 AM
Ordered one off eBay gonna give it a try.
Raul1991 is offline
Old 09-13-2021 | 08:22 AM
rustyus's Avatar
One, or two other designs of a HP 750W server power supply cover...
rustyus is offline
Old 09-13-2021 | 04:43 PM
They look cool, wish I could grab the files for them.
Adam007 is offline
