Micro Servo Help
Old 07-23-2021 | 03:31 AM
Default Micro Servo Help
Hey guys im new to RC. Ive got a Losi Micro 1/24 Rally Brushless.
Sadly the servo have stopped working randomly. Doing some reading on the forums... the servo may have burnt out because i had the dual rate steering on max... and the steering trim was set to very "one side" to straighten the car. Before the servo broke i noticed the steering was very jittery when the car was still.
Losi no longer makes the servo... its the brushless car with 5 wire servo. Ive found lots of 3 wire servos online but the 5 wires i cant seem to find the correct size.
Ive found this online (im in UK): AZDelivery SG90 Micro Servo 9g
I assume i can buy this and simply remove the motor and re-wire it into the original losi servo case? I assume its the motor the burns out and not the controller inside the servo?
In anyone knows of a easier direct fit or easier way of doing this please advise.
Thank you
Pingster
Pingster is offline
Old 07-23-2021 | 05:53 AM
Roelof's Avatar
5 wire can not be replaced by a 3 wire.
5 wires mean that the electronics is not within the servo but in the receiver. You have to modify the servo.....
https://www.ebay.com/p/5011380227?iid=324406049661
Roelof is offline
