Which battery is better
It depends. If we're assuming the lipos are the same brand and series the bigger lipo would have longer runtime but not necessarily more punch because C-rating only comes into play when there's a certain amount of demand on the lipo. (current draw / motor KV) If there's a significant weight difference that comes into play as well.
Now, if you're cross shopping different brands then it all goes out the window because MAH and C-ratings are arbitrary so they can't be compared across brands.
If this is for racing 1/10 I would go for whichever pack weighed less.
Regardless, the 6000mah will give a longer run time. As for 50c and 80c, that all depends on what motor you're running. If your running a stock type motor then you will not see much of a difference. If you're running a lower turn motor, then you will see a difference on acceleration and not much anywhere else. depending on the difference in price is how I would make the decision.
2Likes
