Data logging (amp draw) >
Like Tree2Likes
  • 1 Post By kutless
  • 1 Post By kutless
Old 05-28-2021 | 08:31 AM
Default Data logging (amp draw)
Hey fellas. Anyone aware of a data logger that is not crazy expensive that can track peak amps as well as average amp draw? A graphing function would be handy but isn't totally necessary. The eagle tree elogger V4 would have fit the bill but it looks to be discontinued. I found the toolkitrc wm150 but it doesn't appear to log any data, only shows realtime. It does give peak amps though. Temperature logging would be handy as well but again my primary need is amp draw. Thanks guys.
kutless is offline
Old 05-28-2021 | 08:39 AM
Furadi's Avatar
You could switch you're ESC out for a castle ESC. A lot of them have full data logging.
Furadi is offline
Old 05-28-2021 | 08:43 AM
Do you know which models offer it? I have a mamba max a couple mamba max pros a few sidewinders and a mamba monster. Do you know if the logging works with brushed motors? Thanks! I had no idea castle ESCs had logging.
Furadi likes this.
kutless is offline
Old 05-28-2021 | 08:54 AM
Furadi's Avatar
Ha! check the specs. You might need to order the USB linker but a few of those should have logging.
Furadi is offline
Old 05-28-2021 | 09:03 AM
I have the field link Im pretty sure it can be used as a USB link. I'll just have to borrow a computer and check it out.
Furadi likes this.
kutless is offline
Old 05-28-2021 | 12:08 PM
I've done some reading and I don't believe any of my castle ESCs are capable of data logging. It seems that they didn't introduce that feature on the surface models until the x line. I emailed castle to confirm but in the meantime is anyone aware of a logger similar to the eagle tree? Apparently they are out of business and I don't see much in the way of used ones floating around. Worst case I could buy an ESC with logging but a separate unit would be much more convenient
kutless is offline
Old 05-28-2021 | 12:17 PM
Roelof's Avatar
If you are handy with an Arduino then with an arduino, a memory module and a HALL type current sensor you can make your own logger.
Roelof is offline
Old 01-20-2024 | 03:15 AM
Volition's Avatar
Hey guys I am a bit desperate here. Eagletree have shutdown. And My Disk Died that I had the data recorder software saved on. Does anyone have a copy saved i could download. Oh gosh here is hoping
Volition is offline
Old 02-04-2024 | 09:34 AM
Riketsu's Avatar
I need this software as well.. or at least an alternative..
Riketsu is offline
Old 02-04-2024 | 10:40 AM
Riketsu's Avatar
Hi everyone,
I managed to obtain a copy from an old laptop and just tested it in a new laptop (Windows 10).
Please PM me if you'd like to get a link to a copy of it. If anyone has ideas on how to mass-share it, I'm all ears.
Thanks,
-R
Riketsu is offline
Old 02-04-2024 | 12:18 PM
gigaplex's Avatar
Originally Posted by Riketsu
Hi everyone,
Thanks,
-R
Google drive or some other form of cloud storage, set the share permission to "anyone with the link".
gigaplex is offline
Old 02-21-2025 | 03:38 AM
Default eLogger DataLogger software
Hello,
my old laptop died and i cant find EagleTree DataLogger software to download. Does anyone have local copy?
THX
toldyou is offline
Old 02-25-2025 | 02:54 PM
GerryH's Avatar
I have a copy, but it looks like you can download from the Internet Archive:
https://web.archive.org/web/20230331...order-1069.exe
GerryH is offline
