Like Tree2Likes
  • 1 Post By purplegrape
  • 1 Post By HOTROD716
ESC iPhone friendly
Old 01-06-2021 | 03:56 PM
Default ESC iPhone friendly
What esc are iPhone friendly?
Maclan are only android from what I can tell
Tekin requires PC for firmware updates-
(would’ve gotten another one if iPhone compatible), but allows for programming on iPhone
Hobbywing OTA allows for Bluetooth connection with iPhone for updates and programming
any other options?
purplegrape is offline
Old 01-07-2021 | 09:07 PM
The Hobbywing Axe is a crawler ESC but allows for direct bluetooth programming of the ESC with no adapter required.
A good option is just to buy a cheap windows or android tablet or phone and using that to run your programmer for the esc.
mushroomed is offline
Old 01-08-2021 | 01:03 AM
dan_vector's Avatar
Hobbywing via the HWLink adapter. Works flawlessly on iOS. The adapter can be mounted onto the car if desired but there's really no need as its easy to connect and disconnect.
dan_vector is offline
Old 01-08-2021 | 07:26 AM
mrreet2001's Avatar
R/C Tech Elite Member
Built in WIFI? Boy talk about a way to cheat. Make it though tech on blinky mode. Put car on track. Have someone wirelessly turn on boost before the race starts.
mrreet2001 is offline
Old 01-08-2021 | 07:29 AM
I don’t know about the Wi-Fi, but the OTA module is the size of a transponder
it would not make it through tech
STLNLST likes this.
Old 01-08-2021 | 07:41 AM
mrreet2001's Avatar
Thats what I'm saying. If an ESC has built in WIFI, it would probably make it through tech vs a big dongle hanging off to the ESC like the HW.
Old 01-09-2021 | 12:05 PM
Bsthetech's Avatar
I have the V.1 HW WiFi module. Works great with my iPhone and Pro-stock and Pro G2 ESC’s. No reason to update to the new OTA. Just get the new app.
Bsthetech is offline
Old 01-10-2021 | 02:16 AM
gigaplex's Avatar
Nobody mentioned built in WiFi
gigaplex is offline
Old 01-10-2021 | 06:19 AM
mrreet2001's Avatar
🤷‍♂️ Bluetooth ... WiFi ... same difference
Old 12-06-2024 | 11:17 AM
You're absolutely right, finding an ESC that's fully iPhone-compatible can be a bit of a challenge. Hobbywing OTA is definitely a great option since it offers Bluetooth connectivity for updates and programming directly from your iPhone. Another handy feature for iPhone users is speaker cleaning, which effectively clears dust, water, or debris from the speakers using sound waves. If you're interested, you can check out https://watereject.top for that.
yivekan is offline
Old 12-06-2024 | 12:08 PM
HOTROD716's Avatar
R1 has a nice wifi setup. So to does Fantom(ZTW) iPhone interface via bluetooth
staiguy likes this.
HOTROD716 is offline
Old 12-06-2024 | 12:43 PM
jasburrito's Avatar
Default Skyrc toro 160
I have a few skyrc toro 160 that use Bluetooth. Work great. Even used with 4.5t https://www.skyrc.com/TS160
jasburrito is offline
