New RC truck problem. >
Like Tree1Likes
  • 1 Post By Roelof
Old 11-25-2020 | 11:39 AM
Default New RC truck problem.
Hi everyone new here, sorry if I sound like I havent for a clue (I havent)
So ive just bought a maverick phantom xt but have no steering at all. The throttle and reverse works fine but nothing at all when I try steering. Am I just missing something simple?
Thanks Lee
Vezza91 is offline
Old 11-25-2020 | 11:51 AM
Billy Kelly's Avatar
Check the plugs at the receiver
Billy Kelly is offline
Old 11-25-2020 | 11:56 AM
I've had them in and out, seem to be in properly 🤔
Vezza91 is offline
Old 11-25-2020 | 12:28 PM
Its possible it could have a defective servo. Loose plugs or plugged in backwards I’ve seen before on the smaller brands.
Any settings on the controller for steering? It’s possible that could be turn down
Old 11-25-2020 | 12:37 PM
Roelof's Avatar
If the transmitter has a D/R function, check it. Otherwise swap the thottle and steer connector and see if the servo reacts to the throttle movement,
Billy Kelly likes this.
Roelof is offline
Old 11-25-2020 | 01:06 PM
Yes the transmitter has a d/r setting but I've turned both ways and still nothing.
Vezza91 is offline
Old 11-25-2020 | 02:57 PM
Try switching the plugs in the receiver. The throttle will then work off the steering dial. Steering would be on the trigger. If that doesn’t work then you will know the Servo is defective
Old 11-26-2020 | 03:23 AM
OK will try that tonight thanks everyone.
Vezza91 is offline
Old 11-26-2020 | 09:56 AM
Tried swapping the plugs around, when I swap them I get no response from steering wheel or throttle, change them back and just throttle no steering 🤯
Vezza91 is offline
Old 11-26-2020 | 10:10 AM
Bri
Did you plug the servo plug of the ESC into the other channel of the receiver? The ESC powers the receiver so it will need to be plugged into the receiver to be able to properly test the servo in the other channel.
Bri is offline
Old 11-26-2020 | 02:48 PM
the rc guy's Avatar
was this new? if it was used then Id check servo with a servo checker....night even be rx is bad....
the rc guy is offline
Old 11-26-2020 | 03:18 PM
Roelof's Avatar
Try to rebind the receiver.
Roelof is offline
