Like Tree1Likes
Battery decision
Old 11-05-2020 | 10:18 AM
Default Battery decision
How can I determine which battery to use. I am running a Hobbywing combo. 21.5 brushless motor with a Justock XR10 ESC. Currently, I am running with a Venom 30C 2S 5000mAh 7.4 Lipo. I am not racing this car. I have a Hoovo 80C 7.4 V 5000mAh battery. Will this battery be safe to use?
artron9 is offline
Old 11-05-2020 | 10:30 AM
Roelof's Avatar
I would like to know why you think it should not be safe to use.
As long the voltage is right and the capacity x C value can handle enough current, and that it can. Running 21.5T you can even use the most weakest battery available.
Roelof is offline
Old 11-05-2020 | 10:55 AM
Roelof, thanks for your quick reply! That helped me alot! Ron
artron9 is offline
Old 11-05-2020 | 11:39 PM
DirkW's Avatar
If C-ratings were reliable in any way, shape or form, a higher C-rating battery would actually be safer, as it is an indicator of what the battery can safely provide to the ESC/motor on demand. The battery is not forcing anything into the system.
DirkW is offline
Old 11-06-2020 | 05:38 AM
So you multiply the C rating times the capacity to get the load that the battery can handle, so in this case it's 30C x 5Ah = 150A of constant current
Then you can cross reference the following chart to see that the 21.5T motor will pull a max of 32A which is no where near the limit for the battery:
https://www.hobbywingdirect.com/prod...30318655340659
What will be more important is to track the health of your batteries as they age, you do this by checking the IR (internal resistance), more info here:
Which charger is the best?
billdelong is offline
Old 11-06-2020 | 12:43 PM
Roelof's Avatar
Keep in mind that the high C values are only telling about short moment peak current, nothing about continious while the lower C rates can be a continious current rating. Again the modelcar industry did fuck up the standards.....
Roelof is offline
Old 11-06-2020 | 01:48 PM
More info here where SMC has started providing "True Spec" ratings, hopefully more brands follow suit so that everyone follows the same standard:
https://www.smc-racing.com/index.php...egory&path=180
Another good article here on C Ratings:
http://rctruckstop.com/2019/09/25/ex...ipo-batteries/
