-   -   Internal Vs External antenna receivers? (https://www.rctech.net/forum/radio-electronics/1074521-internal-vs-external-antenna-receivers.html)
hookedup 10-21-2020 07:31 PM
Hey guys, I’m just about done with my 1st 1/5 scale brushless losi 5t!! I have a Sanwa MT 44 and I am skeptical about putting the Internal antenna RX 482 In it.. i use the same receiver in my 1/8 scale stuff & never had an issue with range.. being that this is a 1/5 scale i feel an external antenna is merited? Do you think an external antenna reciever has noticeably longer range?
thanns in advance
Roelof 10-22-2020 01:24 AM
https://www.rctech.net/forum/radio-e...a-routing.html
Zerodefect 10-22-2020 02:53 AM
External. But you can heat the tube, and fold it over so it doesn't leave the body.
The no antenna Rx's are for indoors.
hookedup 10-22-2020 06:21 AM
Originally Posted by Roelof (Post 15705355)
thanks for that thread.. the search engine in this forum is subpar.. from what I’ve read.. it’s advised to use an external but it’s still debatable. Being that this is a 35lb car that can cause damage if i lost signal.. I’m still leaning towards external.. I just don’t want to spend another 100$ on a sanwa receiver. I’ll list it and see if someone wants to swap with me.
Roelof 10-22-2020 06:23 AM
Any basic antenna knowledge:
When the wire antenna is faced up it will have the same receiving strength from all sides. When layed down you will create a direction side sensitive.
