Electronics issue
#16
Found this out there as well as an option to trick your ESC into working with a reversed setup and sensored motors
https://teampowerproducts.com/blogs/...ushless-motors
#18
1) switch motor cables B and C
2) switch Hall sensor A and Hall sensor C which is #2 and #4 on the sensor cable (if you have a ROAR certified cable)
3) adjust the timing of your sensor board which might not be possible without doing some modification.
Andi
#19
#20
Hello!
I am not expert for electronic components, so I have next question. I decided to place a JR 2 lead on/off switch between receiver and cooling fan for brushless motor. It is these OK, because I do not want to burn out something? In summer time is cooling of brushless motor needed but in the winter time the cooling is not necessary so instead of disconnecting plugs out of the receiver I decided to place on/off switch.
On/off switch:
https://hobbyking.com/en_us/2-wire-r...en_us_products
Thank you.
On/off switch:
Thank you.
#23
I have installed heatsink with fan, so I think that the fan is not needed in wide open tracks where is not so much acceleration of brushless motor and the motor is not heat so much, so maybe if I switch the fan off I will save some energy for racing.
#25
Reversing the channel on the radio doesn't change the motor direction on a sensored ESC. The calibration phase will determine whether a high or low signal is throttle.
3Likes
