Battery life way down with motor upgrade
I’ve got a 1/18 scale ECX Torment running a Hobbywing 2435 brushless motor and their 16BL30 ESC, a 12T pinion, a 58 tooth spur with factory height tires that are much wider and more aggressive. With the factory tires and motor our Venom (15022) 1900mah NiHM battery would go 30-45 minutes of hard use but now it’s down to 5-10 minutes. I’m guess the bigger tires and brushless motor are wearing it down or is something else going on I should be looking for? What kind of life should I expect out of a NiMH battery that’s getting used hard and how will it last long term? I don’t mind spending money to upgrade to a LiPo but I don’t want to do that over another issue, thanks.
As should be obvious by the truck I’m new a this; I’m a car guy that got into this with my young son so he could start learning so take it easy on me! If my combo is junk or any of my parts are junk let me know because it’ll be news to me, thanks!
Adding power will hurt run time. A lipo upgrade will improve run time and power. Small nigh batteries aren’t very good for high current loads. If you have taller tires, lowering your gearing will also help (like a 10T pinion or 62T spur, if either is available) to restore run time.
Location: northern Indiana southern Michigan all depends on the day.
yes, bigger tires, hotter motor, less turns, higer voltages, larger pinions, larger motors. all increase amp draw and decrease run time. in nimh battery this is seen faster because of it higher internal resistance over lipos.
but before you make the upgrade/switch to lipos. id check to see if the new esc is in lipo mode. All lipo mode does is put in a low voltage cut off. this cut off is to high for nimh as it easily sags blow it. dramatically shortening run time.
1/18 scale not 1/8 scale
This thread has got me thinking about battery life and maybe a couple of you might be able to answer a question. Between running let's say a 17.5 motor in a buggy or an 8.5 motor with 2s lipo just as an example. What would likely be the extra run time with the 17.5 motor. I know there's a lot of variables but are we talkin 20% longer run time? 100% longer run time? My guess is it would be somewhere in between these numbers. Apologies in advance for going a little bit off topic
if esc dont have a lvc for lipo get a battery buzzer plugs into balance wire ...good cheap and works...around $4 usd
