Battery issue
#16
Just to respond, i am able to drain the battery, after it went into limp mode we ran it around the yard for another full hour nearly and got a full charge out of MAH wise, and it again, lasted only 7min. Losi was kinda enough to send me a new ESC thinking that may be it, but it was def not it. I charged it up ONE more time to put in a co-worker's truck which is identical to mine and still got only 6ish min out of it. So this battery is going to go into the backup pile and i'll just need to order a not crappy one, my own fault for trying to save a few bucks getting an "off" brand unit.
#17
There could be other issues causing premature drain, such as an overheated motor, bent shaft in the drive train, improper gear mesh, etc...
He needs to figure out how much capacity is going into the pack from a fully discharged state first.
#19
#21
Since this seems to be a hot topic, i'll update my co worker bought a Dynamite Reaction s2 20C 5000mah battery with his truck and we ran it in my Losi, and the car lasted 32min on a full charge, so yea, battery is trash.
Now i just need to figure out a good battery for a basher. too many choices, any suggestions?
#22
Lectron is not an offbrand battery. My 6S is a badass battery and I know some racers that, well race with 2s lectron pros.
Zeee or the super cheap brands only sold on ebay and small sites are off brand. 35C may be a lower end battery from them (compared to my 100c) but I bet they would warranty it if you provided all this info to them. You probably just got one that sat too long and the voltage got too low before you got it. Or its just faulty, some bad parts can get past QC.
