Arming problem
I have a 40" cat running 2 880kv motors 2 hobbling 120a esc rated for 38v max.problem is trying to connect a 6s and 4s in series esc wont arm.how can I fix this?
I have no room for bigger batteries
Add a three legged voltage regulator to feed the correct voltage to the ESC.
Never mind, I was thinking the ESC was supplying too high of voltage to the Receiver, then the voltage regulator would fix that. You need to find an ESC that will handle that kind of voltage.
1Likes
