-   -   Receiver problem?? (https://www.rctech.net/forum/radio-electronics/1060110-receiver-problem.html)
Funkydrummer1 02-15-2020 12:20 PM
Receiver problem??
Hey guys. Just got my wheeler built. My boy races it. Had it out last night for some shakedown time. During practice, which was about 2 packs, it ran fine. Was just working out suspension tunings etc.
During qualies is when we started having problems. Seems when the buggy got a decent jolt, it shuts down. What I mean is, no steering/motor but the esc fan and motor fan are still on. Also the receiver led is blinking, and the esc is blinking red/green. We do 13.5 blinky so the esc is normally blinking green. I will shut it down, and restart it quickly and it goes to normal, until it hits a pipe or something just a bit hard then shuts down again. This is what I have:
HB d418
Muchmore fleta 13.5 (new)
SMC rf170 (about half a season)mounted in the rear with male & female velcro. (Nice insulator)
Kopropo 241fh (new) mounted in the rear with male & female velcro.
Kopropo ex2 (new)
I was thinking because of the rx and esc mounted in the rear that it was getting too much vibration from chassis slap?
But it would shut down from a front impact as well. So maybe a faulty rx?
Any ideas?
billdelong 02-16-2020 09:10 AM
try reducing the EPA on the steering, you might be getting brown outs from too much power being drawn from the servo, especially if its a Savox
Funkydrummer1 02-16-2020 02:06 PM
I have my steering speed at 87 and return speed at 80. But I do have the travel maxed out. I have a protek 170t
big ted 02-16-2020 06:32 PM
Check your connections at the receiver? If any of the 3 pin plugs are loose or shorting out can cause similar symptoms.
mushroomed 02-16-2020 08:07 PM
This sounds like it could be a loose sensor wire. Tape the sensor wire down, make sure it is pressed in firmly and ensure there is some slack at each end where it connects to the ESC and motor.
Funkydrummer1 02-17-2020 07:42 AM
Yeah I didnt try the sensor wire yet. Good idea
Funkydrummer1 02-17-2020 08:59 AM
But would a bad sensor wire take out my steering??
Mahjik 02-17-2020 09:17 AM
It shouldn't, but then again what you are describing is strange in itself so you never know. ;)
IMO, it sounds more like an ESC issue than anything else...
Andy Koback 02-17-2020 10:11 AM
Swap out receiver first and then ESC if that doesn't fix the issue. Had an ESC do stuff like this but that was yrs. ago.
Losiracer12 02-17-2020 10:28 AM
It’s most likely the SMC esc
lowspark 02-17-2020 04:22 PM
I had a strange problem last year with steering and motor glitch.
Turns out, I had the wires that ran to the receiver zip tied tightly together, and then zip tied tightly to a carbon fiber brace...
Once I released the wires the glitch went way...
Funkydrummer1 02-17-2020 05:59 PM
Yeah, strange. Never had this problem. I need to buy another rx for my Losi5 anyway. Ill try swapping rx. A bad esc doesnt explain my steering going out but Im willing to try another one if its not a bad rx.
Geezatec 02-19-2020 08:43 AM
At least fans run! you know the batt ok. Unusual Steering & Throttle wen tout at the same time. Try Rebinding TX an RX, then Set neutral position on ESC . With Steering not functioning after you turn in on TX not communicating with RX., that's why I ask to rebind system. Then go from there.
Funkydrummer1 02-19-2020 10:57 AM
Yeah I did a re calibration but not a rebind. I just figured when its bound, its bound. Im on vaca right now. When I come back Imma try some of these suggestions. All electronics are new except for the servo. Yeah, fans still run when it shuts down. No steering, no throttle, esc blinks grn/red and rx blinks. Only happens when it gets jolted. When I got everything ready for the 1st time, I ripped it up-and-down the road and it went fine. Even after 2 packs of practicing it was fine. It only started happening around the 3rd of 4th pack. I don't know if that has something to do with that ... nothing was hot. It would go over a big bump or jump and be fine. It had shut off with just a touch of the pipe. So it varies. But A bump or jump or jolt definitely had something to do with it
Funkydrummer1 02-19-2020 11:16 AM
One thing I was thinking of is, I have my rx antenna wound up and in a shrink tube..so its pretty tight.
