Hobbywing esc
Old 12-11-2019 | 04:19 PM
Naquoc's Avatar
Default Hobbywing esc
Hi,
I am using hobbywing stock esc, when I release the throttle, the wheels stop spinning immediately, instead of keep rolling for a bit. How do I fix this problem?
thanks for your inputs!
Naquoc is offline
Old 12-11-2019 | 04:21 PM
Airwave's Avatar
Is your ESC correctly calibrated? Try to calibrate it again... Or do you have set some drag-brake high value, that will have this effect?
Airwave is offline
Old 12-12-2019 | 06:24 AM
also remove the pinion and check for any binding in the drive train, car should roll effortlessly across the room with a gentle push without the pinion installed.
billdelong is offline
Old 12-13-2019 | 06:51 PM
GerryH's Avatar
You didn't mention what type of vehicle you have. Are you testing with the wheels off the ground? A touring car or other with small wheels won't have enough inertia when you release the throttle to keep rotating.
GerryH is offline
Old 12-14-2019 | 08:20 AM
Anthony.L's Avatar
If you have re-calibrated your throttle and there is no binding in the drivetrain then sound like you have enabled drag brake in the ESC. Check your manual on how to set that.
Anthony.L is offline
