Sanwa speed sensitive steering
has anyone worked out how to change the end points of the servo via telemetry?
I know there are other methods to slow down the servo based on throttle. I do this now.
what im looking for is to contract the end points when speed is very high to smooth out high speed turning.
C-mix will allow you to create a ratio between st, th, aux1 and aux2.
this is great for a car that jumps to the right or left on throttle on accel or deceleration.
I think I understand how it works and im using it.
Curve will allow arc, exp, ...
t-mix allows telemetry data to compensate something like a cold motor that needs a high idle until the temperature comes down.
Perhaps for what you're wanting to do, a mix linking the throttle to the steering dual rate is what you're after, but looking at the manual I'm not sure that is an option (I've assumed Sanwa based on your previous posts and menu item names).
I think if you linked the steering to the throttle or RPM telemetry like this, the car would gain steering as you slow down and create a bit of hooking effect as slow down to turn.
Maybe a better way to do this would be to make a custom curve for the steering? Set the movement around the centre to be less sensitive but to still allow full travel if you turn to full lock.
I dont think its possible. I can adjust a knob or lever to slow down or shrink the steering throw. You can also put this on telemetry to another radio so that I could have a second driver make the adjustments live. I just think sanwa didnt think of it even though its all there. They just didnt make it possible to link the telemetry from the receiver to the steering.
yea its sanwa. You also understand. Those are the things I tried. The curve may work but it’s really just a velocity curve for a single channel. It disregards the speed of the motor. Telemetry does have speed data but in the t-comp and c-comp (which allows a master and slave channel) it doesnt let you have the end points or a point on the curve for the servo.
Just a thought, any way to do it by slowing steering down as throttle increases? I get it's not quite the same, & might produce weird results when coasting at high speed etc. but wonder if it would work well enough?
I can tie the position of the servo to the trigger. But that is used to compensate for torque steer. It works great. Its just the response or end point that cannot be tied together.
