LiPo Storage Charge
Old 09-15-2019 | 02:01 AM
Questions?? LiPo Storage Charge
Hello,
I am new to RC, and I have got a cheap iMax B6AC (non-SkyRC, but that's because it was $20 more expensive) LiPo Balancer / Charger. So far it works great, and I have been collaborating it (It is about 0.1V off I think)
Anyway, I know that you store a battery 3.8v per cell. Currently I have a 3s battery, with the voltages being 3.77, 3.77 and 3.85. My charger indicated the storage charge / discharge is complete (by beeping) but I wanted to know if it was safe to store batteries with this much variance in their cells, and variance around the 3.8v safe mark
Thanks,
Angus
Angus1123 is offline
Old 09-15-2019 | 02:20 AM
Roelof's Avatar
On youtube there is a vid about a real B6 and a fake one
I think this will explain the bad balance. But to be honest, there is no precice voltage to store LiPo, if it is arround 50 to 60% charges then it is OK, as long it is not complete full or empty.
Roelof is offline
Old 09-16-2019 | 06:06 AM
+1
In other words, you want to minimize the amount of time your cells are away from 3.8V on average in order to maximize their lifespan. It's not a hard set rule as there are many other variables which affect the longevity of your cells too, best method I know how to check the health of your cells is to invest in a quality charger which includes an IR (internal resistance) meter. Not the best quality charger, but it includes an IR meter and will give you the basic information you need to check your cells:
Charsoon Antimater 10A Charger
It only offers precision to the nearest whole number where high quality cells tend to start around 1mΩ and will slowly increase over time to the point where they might reach around 8mΩ at about a year old which is the point where the pack starts to have a noticeable decrease in performance. Lower quality (budget) cells typically measure around 3mΩ when new and tend to degrade more quickly where they might reach 8mΩ in as little as 6 months in my experience with about a dozen different brands of budget cells that I have personally tested.
The quality of your charge leads will also effect your IR readings, if you decide to invest in a charger with an IR meter, then do yourself a favor and spend a few extra bucks here:
Trinity Charge Leads
If you want higher IR precision down to the tenth's, where new high quality cells might read around 0.6mΩ instead of 1mΩ and many more features then consider any of the iCharger brand chargers.
More info here:
How to prolong the life of LiPo cells
billdelong is offline
Old 09-16-2019 | 11:39 PM
CarbonDeflector's Avatar
Do you have access to another charger (friend, shop, etc.) that is proven/reliable so that you can test a few cycles and write down the readings? Being that batteries are one of the most dangerous parts of this I'd be wary of skimping to save $ in that area (charger, packs, etc).
CarbonDeflector is offline
