Frequency chips
Old 05-20-2019 | 02:14 PM
Default Frequency chips
Can frequency chips in the transmitter be change to match the existing receiver in a plane.
AFteach4 is offline
Old 05-20-2019 | 02:36 PM
the rc guy's Avatar
tx and rx and chip must be same brand..
the rc guy is offline
Old 05-20-2019 | 02:37 PM
Roelof's Avatar
If you are talking about 2.4ghz systems then the answer is no. On 2.4ghz systems there is a compleet language transmitted which is different with each brand and even with different models from one brand. You need matching receivers....
If you are talking about 27/40/72mhz then thos chips are called crystals and yes they can be changed. Still be aware that some brands -for sure with FM- can use special crystald that do not work with other brands. Also here it is the best to use the right matching receivers and crystals.
Roelof is offline
Old 05-20-2019 | 02:54 PM
Default On tx and Rx crystals
Thank you for clearing that up for me, it is an older Hitec lazer 4 with a 72.070 crystal and a receiver is a Hitec 72.030
Im not sure what radio went with it.
AFteach4 is offline
