Made a shock/diff vacuum pump >
Like Tree4Likes
  • 3 Post By Roelof
  • 1 Post By Roelof
Old 05-09-2019 | 02:57 PM
Roelof's Avatar
Default Made a shock/diff vacuum pump
Also fun and easy to make (if you have the tools).
I found a cheap 12v vacuum pump and some silicone O-rings on a chineese shopping site and managed to get a piece of 60mm acrylic tube, many other stuff I have in the house.
The base with 2 O-rings as a sealing and the pump next to it
The tube fits perfectly
On the center of the base a small 10mm pole with an M6 thread tip, this will fit a diff.
On the pole a stand for 4 shocks can be mounted
Glued a cap on the tube
Made a mount for the motor. At the side of the motor there is a small tube (see 1st pics) which is fitted in an hole through the base, The motor is switched on/of by a small switch.
Finished
On a meter the pump can go as low as 0.3 bar and will hold its vacuum pressure for a few minutes after switching off. After some minutes you can pull off the tube again.
Next time I should buy some lathe toolbits for soft materials for a better finish......
mushroomed, frewster and Oldfan like this.
Roelof is offline
Old 05-09-2019 | 07:33 PM
Maybe you like?
Bry195 is offline
Old 05-11-2019 | 08:07 AM
Roelof's Avatar
I have searched the origin of the picture and saw it was a vacuum pressure switch.
There is no need for that, the vacuum pump I use has a limited power, letting it run can not do any harm.
Roelof is offline
Old 05-11-2019 | 08:19 AM
1/8 IC Fan's Avatar
This is pretty cool. Always inspiring to see home built solutions to otherwise expensive products. Sourcing out components now from Eplastics in the US.
1/8 IC Fan is offline
Old 05-11-2019 | 10:06 AM
Roelof's Avatar
To be honest, the only real costs are the motor, cable, O-rings switch and last a piece of tube I could manage at the local plastics shop. All together maybe arround 15 dollar. The plastic base and the aluminum is stuff I have in bars that is collected over the years for free. (rest pieces are easy to get for free).
The MonacoRC and the Hudy product is arround 120 dollar.......
With about 4 hours of work it is ready. To remind you, all my machines ar no CNC.
Roelof is offline
Old 05-11-2019 | 10:09 AM
1/8 IC Fan's Avatar
Yeah, My mill is manual too, as such I wonder if a square style clear plastic cups may work by chance. I will give it a try.
Old 05-13-2019 | 03:42 PM
platgof's Avatar
How about a syringe?
platgof is offline
Old 08-28-2025 | 06:16 AM
TKW0024's Avatar
How was the base made or what did you use?
TKW0024 is offline
Old 08-28-2025 | 06:21 AM
Roelof's Avatar
The base I made from a large round bar PE on the lathe. On one side made it fit for the tube with an O-ring in a slot and an O ring on the bottom corner. And hollowed on the under side.
TKW0024 likes this.
Roelof is offline
