Like Tree700Likes
FlySky Noble NB4
Old 03-07-2021 | 05:04 PM
  #826
Originally Posted by frewster
I haven't had any issues with range using the FG4RS receivers in my buggies. I get signal as far as I can actually see the car and still drive it.
Thank you, great news! I’ve had this radio for about a week, simply incredible. Blown away by the fit and finish and how easy it is to set up and use.
gwc likes this.
smc3260 is offline
Old 03-08-2021 | 03:52 PM
  #827
Originally Posted by hyper67
Right now the FGR4S seems to be holding a good bind. Yesterday it was the FGR4P that seemed to be holding a good bind.. Now the " P " wont hold a bind. I'm not putting these in my cars till I figure this out.
Are you trying to bind two receivers to the same model?
edit: sorry you figured it out before my response.
dubels is offline
Old 03-09-2021 | 06:26 AM
  #828
Originally Posted by lephil
ok, as a quick follow up on my noises problems. I installed 2 of the same JX servos, noise and jitter was cut 90%, then I set up trim so GAZ servo would have NO tension.
BAM : NO more noise. hope that will help someone, I guess this was not just luck.
Don't forget, digital servos are powered all the time, moving or not. So, they will make noise, hum or chatter when not moving or even under very slight load. Analog only uses power when commanded to move. Of course if it seems excessive, its always worth checking your settings to make sure you have the right servo type selected. If an analog servo sounds like that, its usually bad, voltage too high, or type is wrong. But digital can be noisy like that.
Timw is offline
Old 03-10-2021 | 06:46 PM
  #829
soulcoma's Avatar
the noise is generally dependent on the motors used. Brushless servos are super quiet compared to Coreless motor servos. they also center faster and more accurately.
soulcoma is offline
Old 03-13-2021 | 08:14 AM
  #830
someone had the following error on NB4?
Resources error! Please update the transmiter firmware.
I can not do anything, it does not go from there.
I tried to update but it does not detect it.
LoGar is offline
Old 03-13-2021 | 09:48 AM
  #831
soulcoma's Avatar
have heard about people having the issue but I dont remember ever seeing a fix posted about it. Try to Contact Flysky support. If I hear anything I will post here.
soulcoma is offline
Old 03-13-2021 | 10:41 AM
  #832
I contacted Flysky with no luck, they ask me for a non-existent QR code on my transmitter and claim that without it they cannot help me, very disappointed with the brand
LoGar is offline
Old 03-13-2021 | 11:12 AM
  #833
uhhh, the QR code is on the help page of the system menu, not sure how you would access that if the radio wont boot. Maybe best just to say it wont turn on.
Timw is offline
Old 03-13-2021 | 11:19 AM
  #834
Timw is offline
Old 03-13-2021 | 11:21 AM
  #835
there's mine. I have no idea how going to a sketchy URL will help them, but that's what the QR says.
Timw is offline
Old 03-13-2021 | 06:41 PM
  #836
soulcoma's Avatar
THe Tech support is actually pretty good. Keep in mind the translation sometimes gets messed up. Try and reach out to them again. and make it perfectly clear that you cannot boot up the Transmitter to retrieve the QR code. sometimes sending a vdeo clip helps as well.
soulcoma is offline
Old 03-13-2021 | 10:41 PM
  #837
soulcoma's Avatar
Ok I got some insight. It appears that if your firmware was very old and you try to update straight to the newest version you get this error.
what version did you have originally?
try to install .79 or .83 or something. And see if it updates? If it does then try the .93 update again.
TOM MAR, frewster and gwc like this.
soulcoma is offline
Old 03-15-2021 | 11:15 AM
  #838
soulcoma's Avatar
Curious if that worked?
soulcoma is offline
Old 03-16-2021 | 06:44 AM
  #839
doen08's Avatar
Do you guys know how to update micro recievers to be able to bind it with the latest firmware?
doen08 is offline
Old 03-16-2021 | 08:09 AM
  #840
There is a QR code sticker on mine:
Cromulent is offline
