FlySky Noble NB4
#811
Do you guys have this kind of noise coming from your rx?
http://soundclips.ovh/MOV_0280.mp4
please check my little video, I just installed a digital servo, set the system to digital servos. and this is not some simple jitter.
Is there something wrong with the receiver? Do you guys also have all those kind of crazy noises?
Could it be because I have one digital servo and one normal?
#814
I've read on here that if your digital servos are acting weird then switch your tx to analog for that servo, and see if that corrects the problem. I'm sure someone else will chime in thats more experienced than me though. good luck!
#816
Alright guys, I updated my receivers from the TX and that was successful. I then bound them and that was successful. Then i remove power from the receiver. remove the bind plug. The radio tells me the signal was lost. I reconnect power and most of the time it will recognize the receiver again. but if I power the receiver down, then power the TX down and power the TX back up and then power the receiver back up it wont recognize it. Ive bound these 3 receivers several times and it always binds no problem but its hit or miss whether the TX will recognize it again. Is there anything in the receiver settings I should be concerned with. Like RX interface protocol or RSSI output setup ect..... Just not sure why they bind successfully, no problem and then I power the TX down and back up and it dosnt recognize it. I'm missing something. Just not sure what it is.
#817
#818
#822
Ok, boy do I feel stupid. When I was binding the receivers I wasnt switching the model # on the TX. I figured I could do that later. Wrong ! I was continually binding all three receivers to Model #1. So the last one I bound was the only one that worked. Now I can finally install these puppies and start the model setup process. Stay tuned for more stupidity. Lol. Thanks for the help guys.
#823
#824
ok, as a quick follow up on my noises problems. I installed 2 of the same JX servos, noise and jitter was cut 90%, then I set up trim so GAZ servo would have NO tension.
BAM : NO more noise. hope that will help someone, I guess this was not just luck.
#825
I haven't had any issues with range using the FG4RS receivers in my buggies. I get signal as far as I can actually see the car and still drive it.
700Likes
