charger input voltage >
Like Tree2Likes
Old 01-12-2019 | 11:57 AM
  #16
Roelof's Avatar
The only arguement to choose a higher voltage PSU is just that a lower output current is needed making it cheaper.
But because ther is more to run on 12v like tire heaters, pit light etc the choice for a high power 12v PSU is much wiser.
Roelof is offline
Old 01-13-2019 | 12:43 AM
  #17
gigaplex's Avatar
The X6 is a bit special. There are some situations where it does need a higher voltage PSU to output max power. But not for 2 cell.
gigaplex is offline
Old 01-13-2019 | 08:38 AM
  #18
All the high-power iChargers are like that and probably the other brands too. They have derated output power with 12V supply. I have a six year old i306B and it is the same situation. It's not complicated. At 12V the input current max is exceed before the output power max.
rhodesengr is offline
Old 01-13-2019 | 01:55 PM
  #19
if you knew how 12 volts DC is boosted to a higher DC voltage.. its costly.. and sucks lots of amps..
ac is just Different and much easier to up boost..
chuck_thehammer is offline
