Like Tree2Likes
  • 2 Post By performula
4PLS vs. 4PV
Old 11-16-2018 | 05:20 PM
Default 4PLS vs. 4PV
Are they the same speed? I do not care about features. I cannot justify paying $100+ for ergos or features I will not use.
Bashing, 12th pan, and Touring. Still a noob with racing.
performula is offline
Old 11-16-2018 | 05:42 PM
racknpinion's Avatar
They are both capable of similar if not the same speed with the telemetry receivers, but the main issue I had shelling out for the 4PLS at this time is that the antenna is no longer available as a spare part, and the radio is now about 5 years old, which means more than likely that is due to be replaced very soon. From all accounts its a fine radio, but I wouldn't feel comfortable buying one with those two caveats. Just my 2 cents.
The Sanwa MTS is super fast, and receivers capable of the fastest speeds(RX-380) are only about $10 more than the Futaba receivers if you look around. You can also get the radio bundled with two of the $100ea. RX-482 receivers from RCmart if you're willing to forgo US warranty service.
racknpinion is offline
Old 11-16-2018 | 08:06 PM
I had a 4PLS before until the antenna broke. ...
I have a 4PV for sale:
FS Futaba 4PV with receivers & upgrades
Phillip F is offline
Old 11-16-2018 | 08:24 PM
I settled on the 4PV. I liked the MT44 as well.
1/8 IC Fan and racknpinion like this.
Old 11-17-2018 | 05:04 AM
mes
Ergonomics is why I chose the 4PV over the MT44. Finally a mid-level radio that allows you to use a wheel drop-down and angle adapter!
mes is offline
