Binding problems.
Old 09-05-2018 | 01:37 PM
Default Binding problems.
Hello... this is my first post. I am trying to bind a RedCat RCR 2CE transmitter to a Fly Sky GR3E receiver. It will not bind! Any suggestions? Thanks Rob in Chicago
Robertalan51 is offline
Old 09-05-2018 | 01:52 PM
Marcos.J's Avatar
Super Moderator
i moved your thread to the proper area
Marcos.J is offline
Old 09-05-2018 | 02:08 PM
I’m new here
Old 09-05-2018 | 02:25 PM
OverGeared's Avatar
Here you go...
1. First - Make sure the vehicle and controller are powered OFF.
2. Insert the bind plug into the channel 4 "VCC" port on the R-3E receiver.
3. Turn on the power to the vehicle; this should give you a flashing red light on the receiver.
4. While holding the bind button on the controller, turn on the power to the radio.
- This should give you a flashing green light on the radio, and now the receiver light should blink slowly.
5. Power the radio and vehicle off.
6. Remove the bind plug from the receiver.
7. Turn everything on as normal - remote control first and vehicle second - you should be good to go.
Goodluck. Hopefully this helps.
OverGeared is offline
Old 09-05-2018 | 08:01 PM
As above to bind except the bind plug needs to be in CH 3 not CH 4 for the Flysky GR3E. The Redcat R3E is the same as the Flysky GR3F which uses CH 4 for the bind plug.
Igottabeme is offline
Old 09-10-2018 | 07:15 AM
thanks guys ….I am a little confused by your suggestions but will try both methods. thanks again, Rob
