Like Tree5Likes
LiPO vs LiHV
Old 06-16-2018 | 07:05 PM
Default LiPO vs LiHV
question. Do you need to adjust settings on your esc to run LiHV batteries vs. LiPO? If yes does that mean you can’t switch between the 2 batteries with adjusting the ESC setting before running each battery? Thanks.
ezimmerman is offline
Old 06-16-2018 | 09:00 PM
gigaplex's Avatar
No changes required.
gigaplex is offline
Old 06-16-2018 | 09:17 PM
X2
trigger is offline
Old 06-17-2018 | 07:17 AM
Phat-Boy's Avatar
Originally Posted by trigger
X2
×4
Phat-Boy is offline
Old 06-17-2018 | 10:41 AM
I was running a mamba X in a modified sprint car. When I ran LiPOs it was fine, but I got an LiHV and started having problems. I could not get the esc to calibrate top speed. It kept cutting out around 90% throttle. I ended up smoking 2 motors even though I never get top speed and only ran them maybe 2 to 3 minutes with them cutting out and not really running. So I contacted castle and here’s what they stated.
The ESC is calibrated at 4.2v per cell for the cell count (for auto-lipo). With the HV lipos charging to 4.35v/cell the ESC thinks you're running more cells than you are and cutting off early. You'd want to go into Castle Link and set the cutoff voltage for "Custom" and then in the box to the right you'd put in the total cutoff voltage (ie - 6.4v for 2s, 9.6v for 3s, etc). That should resolve it. Let me know if it's still giving you troubles after that.
I got a new esc (SMC RF170) so I don’t want to hurt that esc or some more motors. I can’t afford that.
Old 06-17-2018 | 11:04 AM
the rc guy's Avatar
the rc guy is offline
Old 06-17-2018 | 01:56 PM
Suspended
Originally Posted by the rc guy
Yes you will need to adjust a esc when running lihv .. most esc are not setup for lihv the smc 170 your going to run with melt down .its not made for a 2 cell lihv.. its a 1s or 2 cell lipo not a lihv 2 cell dont try it.. like castle said to you .use castle link and adjust voltage levels..
just because they sell lihv dont mean any esc will handle them..
Funny , SMC's website says the 170 can run on up to 3s. So I doubt .4 extra volts will hurt anything. His previous issue happened because of how hard it is to run stuff pegged at 90%. Literally a once in a life time thing that wouldn't have happened had he not been running a Castle esc set in "basher switch battery voltage" mode. The fact that it was in a sprint car where he probably runs nearly wide open continuously made the problem way worse.
I would still not run auto voltage detection, just on the off chance SMC did something similar with their auto detection. I doubt they would though because Castle is a bashing brand where they have to protect people from doing stupid things. In a race car you will not be switching between 2s and 3s, so it is better to pick a set cutoff voltage. I pick 7.0V because it protects batteries in case of a voltage mismatch.
urnotevenwrg2 is offline
Old 09-18-2021 | 10:07 AM
Can a HV be charged by a regular Lipo charger? I was told by the LHS you could.
performula is offline
Old 09-18-2021 | 10:14 AM
Alexv2024's Avatar
Normal Lipos get charged to 4.2v per cell and HV lipos get charged to 4.35v per cell. So if you have an adjustable setting or a HV mode then it'll be able to do a full charge on a HV battery.
Alexv2024 is offline
Old 09-18-2021 | 10:38 AM
Your charger has to have that capability to do it.
Andy Koback is offline
Old 09-18-2021 | 10:43 AM
DirkW's Avatar
In racing 4.35V is almost universally not allowed, max. legal voltage is still 4.20V mostly. So for (most) racers, HV cells are just charged to that - with normal LiPo mode.
DirkW is offline
Old 09-18-2021 | 11:26 AM
Originally Posted by DirkW;[url=tel:15825387
15825387[/url]]In racing 4.35V is almost universally not allowed, max. legal voltage is still 4.20V mostly. So for (most) racers, HV cells are just charged to that - with normal LiPo mode.
Does this have an impact on HV battery life/health charging to 4.2V?
Old 09-18-2021 | 12:32 PM
Roelof's Avatar
I work a little bit with electronics. I can do some designing and even SMD soldering but I have never seen electronics that wil get damaged by a 0.3v higher voltage.
gigaplex likes this.
Roelof is offline
Old 09-18-2021 | 12:38 PM
sosidge's Avatar
If anything you'll get more life from the LiHV because it is not being pushed close to its limits on charge.
performula likes this.
sosidge is offline
Old 09-18-2021 | 12:39 PM
DirkW's Avatar
No, no negative effects. All you do is basically stress the cells even less, when you are not chraging them so high.
I've heard that HV cells are supposed to be just selected higher quality LiPo cells, with no real physical difference. Don't know if that is true.
DirkW is offline
