Like Tree2Likes
Rx antennas
Old 05-15-2018 | 08:32 AM
Default Rx antennas
Ok so since I treat everything like trash I destroyed some rs antennas. I was going to cut shielding back, but opened up the rx and the solder points are easy to access. Does anyone know of a place to source antenna wiring for spektrum rx?
notagolf is offline
Old 05-15-2018 | 10:55 AM
Darkgenerals's Avatar
R/C Tech Elite Member
Did you try to google it?
Non BS answer: The model number matters, some use normal wire and some use actually antenna wire.
Thread on RCtech about replacing the wire.
Darkgenerals is offline
Old 05-15-2018 | 11:25 AM
the rc guy's Avatar
like said above some are coaxial wire .other single strand.. make sure you keep correct length.. might want to look in forsale threads. i think i did read a while ago like 2015 a spectrum wire for antenna.
the rc guy is offline
Old 05-15-2018 | 03:43 PM
"Did you try to google it?"
Not very nice Darkgenerals. Just answer his question without poking at him.
Darkgenerals likes this.
rcbuggy88 is offline
Old 05-15-2018 | 05:06 PM
Anytime you have a question about anything, first thing to do is "Google it" I don't think Darkgenerals was poking at him.
Anyway, try E-bay. Friend of mine bought a bag of 20 wires for $10. They were the snap-on kind for Futaba and possibly others as well. Worth checking out.
Andy Koback is offline
Old 05-16-2018 | 04:49 AM
Roelof's Avatar
If you are able to solder a new wire then just try to get an antenna wire in this thin size. The local radioshack could help you. On the other hand if we knew the receiver model number we could look with him for a replacement. And yes, using google with "REPLACEMENT ANTENNA [MODEL RECEIVER]" could give some hits or for sure other antenna's you could use to make it fit.
Roelof is offline
Old 05-16-2018 | 06:11 AM
lol
chastise me and add nothing of value to the thread, while I'm actually trying to help OP.
Old 05-21-2018 | 11:53 AM
I don't think I would trust putting a piece of Radio shack wire on a receiver that controls an very expensive R/C car. These new receivers i.e. ones made in the last 10 years have a coax antenna that is replaceable on spektrum, however I'm not sure about other brands. Don't screw around and crash a car trying to save $5.Just my 2 cents.
cmego is offline
Old 05-21-2018 | 12:33 PM
Maybe you should read how everyone said the model number matters, because some use regular wire, and some use antenna wire. Also have you heard about radio shack? Because I have some really bad news for ya.
Old 05-21-2018 | 01:16 PM
Thats what I'm saying don't put some crappy piece of wire use the proper antenna and Yes I know Radio shack is defunct.Maybe you should read and interpret before replying.
cmego is offline
Old 05-21-2018 | 01:17 PM
Roelof's Avatar
And this is a typical reaction as many people on this forum. You think you know it all but actually with this post you show that you have no clue how it really is. You really think the antenna wire is something special made from golden locks weaved by elves at full moon? Wake up and see it is just an every day cheap wire. With older receivers just a simple wire and with later receivers a coax cable.
Roelof is offline
Old 05-21-2018 | 07:17 PM
You get meme answers because your not helping in this thread.
Old 05-23-2018 | 10:33 AM
Radi0Flyer's Avatar
If you found solder holding the wire to the board then it's single stranded wire. You can buy it from most hobby stores. Here is some backordered stuff from Tower. If you search you can find some somewhere.
https://www.towerhobbies.com/cgi-bin...?&I=LXWZV7&P=9
COAX antennas use a push connector and can be replaced without soldering with replacement antennas like this:
https://www.amainhobbies.com/spektru...648ant/p520524
Sean
Radi0Flyer is offline
Old 05-23-2018 | 12:02 PM
Roelof's Avatar
Really, if it is a plain wire you can use all kind of stuf like a wire from a piece of telephone cable, an old floppy flatcable or a wire from an old broken servo.
The coax is not always a plug but as long no model is mentioned we can not look with TS to see what is arround. But if the coax is soldered you can cut off the connector, strip it short and solder it to the PCB.
Roelof is offline
Old 05-23-2018 | 12:09 PM
the rc guy's Avatar
i have had a few coaxial wires .soldered on top of board then again the center wire soldered on bottom of board .ck sn then replace that type of wire
as you have noticed some think its funny to take jabs at others for asking Q's
I dont
